Philips 42PFL3405H/12 very bright, white picture
  • yohnsee
    Semi-noob
    • Dec 2017
    • 198
    • Hungary
    Hello everyone.
    I need a little help from you.
    This TV was working fine, up until last week. Then it was not turning on.
    I narrowed down the problem to mainboard. As I was unable to solve it on component level, I ordered a mainboard for it. A local guy sold me, from his broken screen set. But in my TV it gives this strange picture, as you can see on the attached photos. I measured the following voltages on the T-con connectors with screen ribbon cables attached and without them.
    Vcom: 16.3V
    H_vdd: 8V
    Tcon_Vcc: 3.3V
    Tcon_vdd: 16.5V
    Vdd_odd: 28V
    Vdd_even: -5.3V
    These values are within 0.2V with screen attached to t-con.
    Also, there is no change in this symptom if I connect only one side of the screen.
    Is there any way to be sure, wether it is LCD screen failure or mainboard?
    I am not 100% sure, the mainboard I bought is working fine.
    P.S: I checked the service menu, and the display code is right for this set.
    Cheers, Janos
    Re: Philips 42PFL3405H/12 very bright, white picture
    Looks like bad Gamma Voltages.
    You need to list the Gamma Voltages.
    We cannot tell from your pictures as where the T-CON board is.
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      Thanks, budm. Tomorrow I list the VGammas.
      The tcon is integrated onto the main board, 3. picture, upper left corner. From there, the 2 white ribbon cables goes directly into the buffer boards (I hope I say it right, the 2 very narrow, long pcbs on top of the display) from there, only cof goes to the lcd display.
      Cheers, Janos
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        i take it you tried turning the brightness down ?
        • yohnsee
          Semi-noob
          • Dec 2017
          • 198
          • Hungary
          Yes, I have. I don't have any black on the screen, the startup logo is also the same white-on-even whiter as the rest.
          Cheers, Janos
          • ducky29
            • Dec 2015
            • 370
            • Europe
            Try changing the display code on the service menu and match it to your screen.
            • yohnsee
              Semi-noob
              • Dec 2017
              • 198
              • Hungary
              Thanks ducky29, in the first post, I mentioned, that I matched the display code with the sticker on the chassis. Or should I try random 3-digit numbers?
              Cheers, Janos
              • ducky29
                • Dec 2015
                • 370
                • Europe
                Sorry didn't read the whole thing. Looks like a panel fault based on the 2 screen photos that I saw.
                Does it change if you let the tv running for some time?
                Try the menus, if you look closely, does it leave marks, shadows after closing the menu? If so the panel/ tab bonding faulty.
                Or Try a factory reset or a firmware update.
                • yohnsee
                  Semi-noob
                  • Dec 2017
                  • 198
                  • Hungary
                  A very big THANK YOU, for putting me on the right track. Indeed, the gamma voltages were wrong. Vgm1 to Vgm5 every reading was the same, 16.2V. So I suspected the gamma IC (U7051) MAX9668. Luckily, I have a donor board laying around, I swapped this IC quick. See photos, this is the result. I call this progress. The left side is perfect, the right side needs more work. If you have any idea, what could it be on the right side?
                  Cheers, Janos
                  • yohnsee
                    Semi-noob
                    • Dec 2017
                    • 198
                    • Hungary
                    Thank you ducky29, I try every other option before I call it a display failure. I made a small progress, please see pictures above.
                    Cheers, Janos
                    • yohnsee
                      Semi-noob
                      • Dec 2017
                      • 198
                      • Hungary
                      Please take a look at these 2 pictures.
                      I turned the TV over, to make better quality shots.
                      I don't know, what could be still wrong on that side, but as I see a pattern in the problem, I want to think it is not a bad lcd panel.
                      Since my last post I've done the following:
                      Measured every pin on the wrong side with DMM, voltages are the same with screen attached and without. Signal waveforms were not tested.
                      Swapped U7052 (Level shift IC), no change.
                      Currently waiting on a new motherboard, to see, whether am I right or not. And because I don't have enought knowledge to solve this on component level (yet).
                      Cheers, Janos
                      • Schwoin
                        Philips 243v5lhsb00 Monitor Picture too bright
                        by Schwoin
                        Hey everyone,
                        the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                        While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
                        you can see them on the top half of the photo.
                        At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                        03-21-2023, 12:40 PM
                      • Rauni
                        Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                        by Rauni
                        Hello, this is my first post on this forum, and my first attempted to repair a TV.
                        My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                        Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                        Read also that we should test what happens if we...
                        10-01-2023, 12:06 AM
                      • charlesdutcher
                        No picture issue in Philips Chassis FTL2.1
                        by charlesdutcher
                        My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                        Is there someone having any symptom like this? How to fix it?
                        Thanks in advance!​
                        08-06-2024, 09:55 PM
                        MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                        This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-06-2024, 07:46 AM
                        MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                        This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                        09-06-2024, 07:29 AM
