Vizio D58u-D3 failing leds, seeking strips or leds
  • cayala75
    replied
    Re: Vizio D58u-D3 failing leds, seeking strips or leds
    maybe is a little late, but congratulation to both, Is good to know that exist people like Charleyd willing to help and save the planet avoid electronic waste.
  • dragonsbb16
    replied
    Originally posted by Charleyd
    Congratulations! Remember to get the "good" side tabs tucked into the protectors.
    I actually never even touched or untucked the good side tabs.
  • Charleyd
    replied
  • dragonsbb16
    replied
    Wow. Worked like a charm.
    See images.
    Thank you for all your help and suggestions.
    Horizontal lines are gone. Picture is perfect.
  • dragonsbb16
    replied
    Moment of truth....tabs have been removed clean. Hair dryer worked like a charm. They came right off nice and smooth.
  • dragonsbb16
    replied
    I have actually seen YouTube videos showing people using heat. The glue holding the tabs on will soften with heat. Look here starting at around 55 seconds:
    https://www.youtube.com/watch?v=vyKOL-Xwo1Q
    I did see that video. Though i was concerned because it showed them fixing the tabs on the lower address bar, which gets fed from the Tcon board. This vizio simply has Tcon board to bottom address bars (left side and right side), then 8 ribbon tabs on the left and right sides (which have not physical chip board.
  • dragonsbb16
    replied
    Well i dont actually have a "heat gun" but I do have a hair dryer. I guess it cant hurt. I just wont place it very close to the panel in hopes of avoiding any heat damage.
  • Charleyd
    replied
  • dragonsbb16
    replied
    Peel them off. And if something gets left behind, I would turn on the TV before trying anything aggressive to remove the remnants. (Also, I made a post that went to the previous page (Page 2) of this thread. You need to remove all 8 of them.)
    I am definitely going to use your "peel from both sides" approach to hopefully eliminate any part of the ribbon tearing.
    Would using a hair dryer to "warm up" the tab connections loosen or is that heat not hot enough to do anything?
  • dragonsbb16
    replied
    Sounds good. Yes I saw that post. Remove all or none.
  • dragonsbb16
    replied
    Here is upclose pic of the tab closed to bottom of tv.
    It sort of looks like there is about 1/16" that looks like it is connected to the panel. So maybe cutting it off is no good.
  • Charleyd
    replied
  • dragonsbb16
    replied
    The control and power for the side gate drivers comes from the T-Con, and then is fed through the bottom edge boards to the outer-edge of the last bottom flex connector at each corner and then into the panel. Then through the panel itself up to the side tabs.
    Got it (i think). So should I tear them off or use a Razor and cut them clean with the panel edge?
  • Charleyd
    replied
  • dragonsbb16
    replied
    Also, not sure if you can see it on the pictures of the side tabs...on the Vizio there is not side address bar. So the side drivers dont appear to be connected to anything. It almost likethe tab is integrated into the panel somehow.
  • dragonsbb16
    replied
    Do you know of any youtube videos that show the the tab removal process? I havent found any just yet.
  • Charleyd
    replied
    The side tabs work in a bucket-brigade fashion. The T-Con sends a Start signal to the first (top) one to start, and when it finishes driving its corresponding 1/8th of the screen, the IC in the first tab sends a trigger to the second one to start, and so-on. So they must all be good or all be removed.
  • dragonsbb16
    replied
    Originally posted by dragonsbb16
    On the good side, I haven't really done anything with the tabs or black protectors. I will confirm, but those should still be ready to go.
    This is my last shot. If this doesn't work, the TV will be out at the curb next Wednesday morning.
    If I remove 1 Tab on the bad side could i test the image and see if that "horizontal band" is fixed? OR do I need to remove all 8 tabs before testing?
  • dragonsbb16
    replied
    Yes I (and others) have physically removed tabs on one side of a TV panel and the TV worked essentially good-as-new. I expect that you are about to save your TV. (And on the good side, make sure that the black protectors are in good shape and the tabs are tucked behind them. Be gentle with the tabs.)
  • Charleyd
    replied
  • howardc64
    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
    by howardc64
    Failure Symptom
    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
    Where is the short?
    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
    05-27-2025, 02:56 PM
  • edugimeno
    About replacing individual LEDS on BL strips
    by edugimeno
    Hi There!
    Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
    At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
    How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I...
    11-07-2022, 11:12 AM
  • Kingfreddie
    LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
    by Kingfreddie
    Ok.. this is the story:
    Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
    This is kinda how it looked, just that mine were at the bottom of the screen:
    09-11-2021, 01:57 AM
  • smort
    Backlight Polkadarks
    by smort
    Soooo, I found someone giving away their 70" Vizio TV because it wouldn't turn on. Hoping it would be just some bad caps, I snapped it up. No dice. No bulging caps. TV would start consuming about 7W immediately after plugging it in, but no response from the remote or power button. Thermal showed the main chip on the mobo getting warm and nothing else. Power supply appeared to deliver stable 12V to the mainboard.
    I ordered a replacement mobo(actually both mobo and PSU just to be sure) and popped it in. Picture! Sound! Endorphins! Then I noticed three long dark strips. Hmmm, had...
    03-11-2025, 12:33 AM
