Panasonic P65ZT60 Won't turn on. LED blinking 3 times
  • lwrs10
    • Nov 2018
    • 10
    Hey all,
    Troubleshooting my 65" Panasonic TV....trying to revive it. It will not turn on. The power LED flashes 3 times.
    Reading through the service manual this means 3.3v SOS, and points to the A board. Since this board is simply not available anymore, I would like to verify its the A board and attempt to fix it.
    I have a Fluke 87V and an old Tektronix 465 Oscope, and the knowledge to use them.
    I would GREATLY appreciate it if anyone can help me revive this wonderful plasma 65" TV!
    *I think I have most of the service manual and the troubleshooting tips.
    https://drive.google.com/drive/folde...ENxVVJSQjU5ZVE
  • lwrs10
    • Nov 2018
    • 10
    Re: Panasonic P65ZT60 Won't turn on. LED blinking 3 times
    Bumpaloo!
    • lwrs10
      • Nov 2018
      • 10
      Bump. I really want to fix this thing. I've exhausted my knowledge on it.
      • bobbyskillz
        • Dec 2010
        • 76
        It'd definitely help if you posted pictures of the boards and your voltage readings at the connector(s).
        • lwrs10
          • Nov 2018
          • 10
          Since it won't turn on, the only voltage present is the 5v standby voltage. And its there. which boards would you like pics of?
          • lwrs10
            • Nov 2018
            • 10
            Found a brand new A board for $99! Hopefully this fixes my problem.
            • lwrs10
              • Nov 2018
              • 10
              A board did not fix it. Did some more troubleshooting, and when I unplug the "SS" board, TV will actually turn on. No picture, but that to be expected.
              This board is shorted to ground on the +V input, so seems to be the culprit.
              so, ordering the "SS" board now!
              • SLB007
                Panasonic TX-32C300B stanbye light blinking 13 times
                by SLB007
                I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components
                11-02-2025, 04:08 PM
              • Msb1xr
                Have to turn on 77” LG C1 multiple times to get to come on
                by Msb1xr
                Have to turn C1 on and off multiple times for it to fully come on
                Have to run LG C1 on multiple times for it to fully work
                If I have it off for a while I have to turn the TV on and off and handful of times for it actually display what it's suppose. The times it doesn't nothing comes up like the input or dobly vision logo. Once it's on I can turn it off and back on fine and the picture looks perfect.
                Unhooked everything except antenna. Reset tv to factory settings. Let it sit and when I tried 2hrs later turned TV on and sound comes through but no picture....
                10-13-2023, 04:09 PM
              • ahmarzo
                Hp 15-cs laptop 5 times dc jack blinking white
                by ahmarzo
                I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                12-28-2024, 04:46 AM
              • YasaCh
                Sony kdl 40p5500 red light keeps blinking 3 times
                by YasaCh
                Hello...
                my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                i opened the back cover no sign of damage on the powery suply or motherboard
                when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                07-07-2025, 11:53 AM
              • CoinCoin88
                Panasonic PF50G20S blinking 13 times
                by CoinCoin88
                Hello there,
                Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
                Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
                06-30-2023, 05:43 AM
