Samsung Vertical Lines
  • cbearden
    • May 2015
    • 19
    After repairing this TV, from this thread,
    https://www.badcaps.net/forum/showthread.php?t=70191
    all looked good and worked for about a day after I put it on a wall mount.
    Now I get vertical lines on both sides of screen.
    Is this TV doomed?
  • cbearden
    • May 2015
    • 19
    Re: Samsung Vertical Lines
    I've swapped both boards, outlined in the red square.
    Same result after each swap.
    • CapLeaker
      Leaking Member
      • 8196
      check the tab bonds.
      • cbearden
        • May 2015
        • 19
        Yes, this TV had an issue where half of it was very dark on some screens.
        So, I already cut off the tabs on the left side as a last-resort after trying many other fixes that didn't work. It looked and worked great for about 1 day. And then these vertical lines showed up.
        • cbearden
          • May 2015
          • 19
          Or, were you talking about the tabs on the bottom of the screen?
          The tabs I cut off were on the left side.
          • Falki
            Colorful LCD Vertical Lines on Samsung ue55es8090
            by Falki
            Hello there, ive recently found an older 55inch Samsung SmartTV.
            A similar issue has been posted as well but also with no actual response ...
            08-12-2025, 04:19 AM
          • Stanley1843
            by Stanley1843
            06-29-2024, 11:54 AM
          • x_orange90_x
            Samsung UN46C8000XFXZA vertical bars/horizontal lines
            by x_orange90_x
            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
            09-04-2023, 12:09 PM
          • polaro
            Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
            by polaro
            Greetings,
            I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
            08-27-2022, 08:46 AM
            09-07-2024, 05:50 AM
