NEC X551S Digital Signage - No picture backlight present
  • Frx97
    • Dec 2014
    • Italia
    Hi All!
    This one got me stubbed, I found this NEC X551S Digital Signage display at my local recycling center, fortunately the panel didn't get smashed (since they handle junk they don't take much care).
    When connected to power it turns on, the backlight lights up but the display remains black. If I let it sit there for 10 seconds or so it goes in standby. I tried connecting both VGA and audio, the display remains on and I can hear the audio coming from the internal speaker.
    After I popped the back cover open (which required removing a million screws) I got out the thermal camera and noticed that the TCON wasn't heating up. A quick check with the multimeter showed 0V on both sides of the fuse.
    Looking at the main logic board, I found the circuit that turns on the voltage rail, the enable is missing.
    Having nothing to loose, I cut the enable line and tied it to another “working” one. Now I have 12V to the TCON but the display is still black…
    This is the first time I encounter this problem, I usually see the opposite: picture with no backlight.
    I have a background in MacBook board repair, in that case a bad screen could also be caused by a bad/incompatible EDID firmware on the TCON's EEPROM. Could this be the case? The logic board does not like the display so it doesn't turn on.
    Should I replace the TCON? Since I don't know what I'm going to do with It I want to keep the expenses to a minimum. If I can find the EEPROM's dump I may just replace that.
    I Haven't tried poking the LVDS connector with an oscilloscope, but I'll do that as soon as I get some time to set it up.
    Thanks!
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • LaPCon_IT
    Samsung UE50TU7099U no picture no sound, backlight present
    by LaPCon_IT
    TV has one combo board (VTT55UH160). Symptoms are like this.
    When part of the screen is disconnected (white part), it looks like this
    Resistance and voltages (I don't know if they are good or not). The inductor with 0ohm/0V seems to be connected to GND.
    I haven't noticed any shorts on rails listed below:
    VGH - 30V
    VGL- -9V
    VAA - 14V
    VCOM - 5.6V
    STV - 11.95V
    LC1, LC2 - +30/-12V
    All CKV lines (no shorts between them) looks the same:
    I've tried to cover some lines with...
    12-15-2023, 03:55 AM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
