42 Inch Plasma TV with bad caps
  • dropfry
    • May 2009
    • 19
    Greetings. This place is e excellent.
    My tale of woe begins with a 42 inch 42PC3D-UD.A1
    Here's a link to a very hi res picture of my tv.
    One day the picture went out and only the sound comes on.
    I opened it up and found 9 swollen Samwha 3300uf 10V caps (Purple squares on powersupply). So I replaced them and tried firing it up. No dice. Probing around with my voltmeter I found a bad fuse on the Y board, so I replaced that as well (Purple square). Now the tv makes a click sound (around where the red box is) and shuts off after about 3 - 5 seconds.
    Everywhere else online that Ive looked says to replace the Y, the Y and Z, or the Y, Z and control board. That seems lazy to me. Im buying an oscilliscope off ebay and learning how to use it, even if it ends up costing more than a replacement board.
    In closing, does anyone have an idea as to what components I should test out first?
    This is the manual Ive been pretending that I know how to use. (I realize this is dangerous, but I try to stay cautious. I ground myself and try to keep away from all the HV stuff.)
  • ran
    • Oct 2006
    • 71
    Re: 42 Inch Plasma TV with bad caps
    With all the help I've rec'd on this forum, I wish I had some sage advice to profer, but alas I do not.
    ...but I hope someone else will chime in with some good info.... I'm curious if you can fix this.
    BTW, what kind and how much for the oscilloscope. I've been sorely tempted to get one myself...but have held back due to my ignorance....
    Integrity - doing the right thing even when no one is looking
    Freedom - not the right to do as you please, but the liberty to do as you ought.
    • Wizard
      • Mar 2008
      • 2296
      YSUS board is gone due to the fuse popped when the big unobtainium IC failed and shorted out. Get another board. This is two reasons I do not like plasma units is cost of getting parts is expensive and not very component-level friendly repair. Second, these *consume* real high watts (330W to 360W) vs rear projection CRT based (under 250W) or as not as bad with LCD panels but still bit high. I'm talking apple to apples (40" to 42" inch size range).
      Cheers, Wizard
      • dropfry
        • May 2009
        • 19
        Cheers, Wizard
        Thats troubling, Im still going to go component by component unill I figure it out. Id rather spend weeks looking for some proprietary chip thats coded in a dead language. Maybe Ill google how to program IC's. The internet is a great thing. Ill post any progress or me smashing the bastard with a hammer as it happens.
        And to Ran, Its a Textronics 7900 series. Guy sold it to me for $150, Ive seen some sell for 280$ including shipping as-is on ebay. I hear 100mhz is more than enough though, this one is 400.
        • dropfry
          • May 2009
          • 19
          Wizard: How do lcd tvs stack up to plasma as far as repairing them. What about the LED versions. Are those going to be bullet proof?
          • dropfry
            • May 2009
            • 19
            unobtainium IC
            Model number: STK795-811A
            If anyone else has this problem: here is some similar if not exact situations.
            I have no real idea what Im doing other than desoldering and soldering. I hope the IC was faulty on its own and nothing on the board killed it. Glad to see he had the same bad caps I did.
            Edit: Our LG's are different model numbers, but the Ysus boards are the exact same.
            • Wizard
              • Mar 2008
              • 2296
              Exchanging ICs on any YSUS board is extreme diffcult due to extraordinary heavy copper planes for desoldering. Another issue there might be bad parts on the YSUS board also when was taken out during STK destruction. And that IC might be only in minimum qty required. And I find that suppliers don't sell this IC singly even our electronics supplier don't sell this, just checked moments ago.
              Good luck! 150-300 bucks is to be expected. But the 150 is repaired or used board. Bit risky.
              Cheers, Wizard
              • Wizard
                • Mar 2008
                • 2296
                LCD, LCD with LED lighting, LED DLP are more reliable but expected to have bad caps and occasional IC failure. Mainboard, T-CON (small board between LCD and the mainboard) and other items are repairable or replaced and not too badly on cost. I dismiss DLP that uses lamps and color wheel (they do make noise and do fail on occasion) as these two items cost big fortune to replace when bulbs or colorwheel fails and serious dust magnet. LED DLP does not utlize the colorwheel and no rainbow effect.
                Just that plasma panels are the ones worse because of design issues in STK ICs. Samsung have moved away from STK modules for plasma and used far more reliable drivers boards using individual transistors and far more compact.
                If you are really wanted to repair your plasma, you want to consider if this panel is 1024x768 or 1366x768 by tallying the total cost and effort and see if you can just toss the tv and get 1080 LED DLP or 1080 LED LCD.
                768 or 720 panels are worst to have as there is none that fits for 480, 720 or 1080 (either downconverted or upconverted) and need to use external box or HTPC to scale up to their native resolution to enable 1x1 pixel mode, not all models do this to avoid notoriously bad scaler built into the flat panels sets.
                Cheers, Wizard
                • dropfry
                  • May 2009
                  • 19
                  Im just going to buy a replacement board and sell this thing for 400 then. If the board doesn't fix it then atleast I can return it. Will post ridiculously elaborate plasma tv smashing if this doesn't work out. (Its 720p) Thanks again for the heads up.
                  • rogueseal
                    • Jul 2012
                    I really wanted to know how this turned out as I have the exact same board with same blown fuse and 9 bad caps. Anyone know if the board fixed the issue. I can get a replacement for 70.00 and new caps for less than $15. The TV was being tossed so at least I get an education and can return the bad board. Any thoughts?
                      Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
                      This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
                      09-07-2024, 12:40 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • black6host
                      Replacement caps for Samson Resolv studio monitor 65A Amp board.
                      by black6host
                      Good day!
                      I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                      I'm going to replace the caps and I'll be the first...
                      02-06-2024, 08:22 PM
