Samsung UE32F5000
  • Billsy
    • Oct 2018
    • 53
    • United Kingdom
    Samsung UE32F5000
    Hi all this should be a quick one. I have a 32" Samsung with a pixel width vertical green line on the left hand side. The line fades out towards the bottom. It appears a couple of minutes after startup so not from cold. I've poked around and manipulated ribbons and such, and nothing has any effect on the line.
    If I remove the left side tcon ribbon, the left side of the screen is completely white and no green line (to be expected?).
    I'm guessing the LCD in a goner? A tcon fault won't create a single line will it?
    tcon = 5351TP0055FV
    Thanks for your help
  • Billsy
    • Oct 2018
    • 53
    • United Kingdom
    Re: Samsung UE32F5000
    Does anyone think it's worth trying another tcon board?
      Panel problem.
      • Diah
        • Feb 2013
        • 6395
        warm the left corner up with hair drier and see if this line disapear
        • Billsy
          • Oct 2018
          • 53
          • United Kingdom
          Thanks very much. Great document.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            NOT T-CON Bd. problem. This is definitely a PANEL problem.
              09-07-2024, 05:50 AM
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
              09-06-2024, 11:40 PM
