Hi-level 48uhl950 dump
  • ugura09
    • Jun 2016
    • 93
    • aydın
    17mb100 vestel maİnboard
    U26 - U27
    Aldanırsın Yıllara
  • Ahari
    by Ahari
    I...
    08-13-2025, 06:12 AM
  • Davy no Caps
    Vestel 17MB82S EEprom dump required
    by Davy no Caps
    First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
    Power Board - 17IPS11
    Mainboard - 17MBS82S
    Panel - VES315WNDB-02
    Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
    Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
    No picture, backlight or sound just blinking...
    06-06-2025, 03:22 PM
  • lanada
    dump file for vestel 17mb110p
    by lanada
    Chassis vestel 17mb110p
    Panel:ves430undl-2d-n12
    Make Toshiba 43l3733dg
    Does someone have a dump file for the main board 17mb110p ?
    regards and thanks in advance
    05-05-2023, 10:40 PM
  • mkdj
    by mkdj
    Dear all,
    10-19-2025, 04:41 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
