LG 60pb5600 unidentified reboot
    I have a plasma TV that is sometime restarting for no reason.
    I replace the power supply and still have the same problem.
    If I unplug everything except the power supply and the main board.. still have the same problem.
    So, I conclude the problem is from the main board.
    I have redone all solder joint that was looking poorly but no change.
    Do you guys have any clue of wich part I should replace ?
    Re: LG 60pb5600 unidentified reboot
    Look for cold solder joints on the PSU. Especially the components on the heatsinks and those transformer legs.
      I see shopjimmy has a main board repair kit, 2 larger ic's and the eeprom so maybe that would fix it?
        Is the eeprom coming pre-programmed? If it is then you can give it a try or you can look for a another Main Bd. I missed in your original post where you mention that you replaced the PSU already.
          Thank you Andrew F. Ali
          R_J Yes I know ! but the fact that the problem is intermittent not sure if its ICS .
            Perhaps you have loose cable connector?
              Andrew F. Ali -> I dont think so. But to me a bad eprom will fail instantly not some times , not sure that is the problem. Is there a way to test it ?
                Andrew F. Ali -> cables are fine
                  Originally posted by olivier.gendron@gmail.com View Post
                  Andrew F. Ali -> I dont think so. But to me a bad eprom will fail instantly not some times.
                  I agree with you here. A cold solder in the CPU could cause this too. Do you have a Hot air Station?
                    No, but I tried with a heatgun twice, same problem, there is a lot of plastic component so wasnt that hot. I'm good at soldering, maybe i can try to carefully heat all the pins.
                      That's a lot of pins that are very close together. Have you considered just getting another Main Bd. off e-bay or Amazon??
                        This is not so bad ! I'll try and let you know
