I need upgrade_loader. pkg for LED TV Philips 24PHK5619 / 12
  • saud52
    • Aug 2015
    • 24
    • Bosnia and Herzegowina
    I have a problem with the Philips software, I hope you can help me ? I need this:
    upgrade_loader. pkg for LED TV Philips model: 24PHK5619 / 12, chassis:
    TMP14.1ELA, serial number: FZ2A1448041524.
    Symptoms of failure: TV crazy behavior has an image, the menu can be called enter into it, but there can no in it either program the channels and andere programming . TV does not respond to commands with remote - simply blocks ! We can not turn off the TV with the remote.
    I have a similar upgrade_loader.pkg for the TNP14.1ELA chassis and I tried with
    their upgrade. The upgrade has passed and the TV with remote control can off and turn on, but I do not have any pictures at all! I have a screen backlight . New upgrade software does not pass through and there are no suitable drivers for the screen , so i do not even have an image and the OSD on screen.
  • SemDex
    Philips 32PFL3008H/12 Remote doesnt work
    by SemDex
    Hello guys,
    First post here so sorry if ill do any mistakes..
    Got TV for repair, Philips 32PFL3008H/12, Main board VESTEL 17MB95S-1 170912. TV turns on, has image and everything, but there is no response to remote controll. Checked IR receiver - it gave no signal at all. Replaced IR receiver with no luck, still no response to remote, but i got proper waveform when any button is pressed. so far i tried ruling out software - flashed EEPROM / BIOS / NAND, no luck. At this point, when turned on, TV displays message "SHOP MODE", message closes, tv works as intended....
    10-12-2021, 03:07 PM
  • kalauzz
    Philips 47PFL5028K/12 - Remote Control repair help
    by kalauzz
    my remote control for my beloved TV (Philips 47PFL5028K/12) is no more working.
    Codes of the remote should be :
    PHILIPS 996590004895, YKF314-005
    It's blinking endlessy when I insert AAA batteries.
    Checked cap seems ok, the transistor (i think is that) seems good
    IC not checked.
    I thought also to a stuck key.
    I switched cap and seemed to be ok but it restarted blinking endlessy again..
    May the IC fail if battery polarity is inverted? because my son told me he did that ...
    The schematics...
    09-08-2021, 08:26 AM
  • cstout
    DeLonghi AC Remote only accepts 3V
    by cstout
    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
    I can't find any schematics...
    06-03-2024, 03:53 PM
  • Mc_Millian
    Toshiba 50lf711u20 fire tv remote not pairing
    by Mc_Millian
    I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
    The Tv model number is: 50lf711u20 Rev B.
    I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
    I've tried 3 different remotes which should be fully compatible with this TV.
    Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
    The power button, along with the volume,back,select, and directional...
    04-07-2022, 12:15 PM
  • edugimeno
    HiSense 55A7500F won't obbey to remote after power on
    by edugimeno
    Hi! I have this TV set that does the following:
    1) I press the red power button on the remote
    2) The TV turns on normally
    3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
    4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
    Then after it's off, it would again accept the TURN ON from the remote and same again
    BUT:
    -The remote does show the correct IR beam while observed thru a phone camera
    -The TV works fine while using the MiRemote...
    03-14-2023, 11:22 AM
