Sharp TV - Solid Red Light
  • Rainy
    • Sep 2018
    • 14
    So, I've been through almost three power supplies on this TV now
    The first was all sorts of bad....
    The second I got a solid red light, thought it was the standby.... That came from ebay without being in a anti-static bag.
    I got another one, and it does the same exact thing from the same seller.
    https://www.sharptvusa.com/support/l...u/users-manual
    The TV in question above.
    Any help is appreciated, do you guys think a firmware flash would help? I really can't afford to order more parts for the TV if they won't work.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sharp TV - Solid Red Light
    We need pictures of the TV with the back cover removed to see the boards. Have you taken any voltage measurements? If so what are they? You question is valid but vague. I would think we need more information from you as we do not have the TV or the PSU in front of us and to do along distant troubleshoot, photos are a must.
    • Rainy
      • Sep 2018
      • 14
      ok, just tired..
      The 18V reads 21.5v
      the 12v reads 12v
      the STB reads 85mv
      the SW and other hot leads are about 0.1mv
      The grounds are all 0
      But this set is so new I don't think the board has a diagram. I tried fixing the last two boards thinking something is wrong with the STB, but I get a red light on. I also spliced the STB to maybe feed 5v dc into it.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        I can't see the photos. The voltages are not correct. can you confirm that your DMM is working properly and what did you use a GND?
          STB = PS-ON
          SW = BL-ON
          PWM = PWM Dimming
          So your main board is not sending those command signals, they should toggle when switching the TV power ON and OFF.
          • Rainy
            • Sep 2018
            • 14
            What is the DMM? I just used the tv ground as ground, like a screw hole. Works great.
            Originally posted by budm
            STB = PS-ON
            SW = BL-ON
            PWM = PWM Dimming
            This is why I was wondering if there is a firmware somewhere I can re-flash the tv with.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              DMM is Digital Multi-Meter.. ...I don't think it is a Firmware issue, but do think that the Main Bd has a problem.
              • Rainy
                • Sep 2018
                • 14
                I would kind of agree with you at this point but I want to test my backlight.
                How can I jump start the power board to test the backlight?
                Thanks.
                This is the top-down view of the board (my camera is dead):
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  Disconnect the connector on the PSU that goes to the Main Bd. Connect two (2) AA batteries in series to give 3V. On the underside of the PSU on the connector that would have gone to the Main Bd. very carefully solder the battery +ve to the STB=PS-ON pin and on the SW=BL-ON pin (as described in Post #5)and the battery -ve to the GND pin. Inspect your soldering to verify there are no shorts to adjacent pins and the connections you made are solid. Plug in the ac and if the PSU is good the Backlights should come ON. Measure for other voltages generated on the PSU are correct and if the are then your PSU and Backlights are good.
                  • cajoeg
                    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                    by cajoeg
                    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                    02-10-2025, 04:01 PM
                  • roy.zhero
                    Sharp LC50LE752E no picture and backlight, indicator light is lit
                    by roy.zhero
                    I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
                    When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
                    When I hold the force-on-combination it will turn on. It then shows a perfect...
                    09-20-2020, 01:57 PM
                    Lithonia Lighting versus Light of America Compact Fluorescent product quality
                    I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                    I also have back when Light of America had these light bulbs available for yard lights
                    The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                    While the Lithonia lighting fixture has all most certain bulb failure
                    So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                    I have only had this light fixture for not more than a year if it...
                    07-02-2023, 03:45 PM
                    LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                    This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 03:40 AM
                    LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                    This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 09:10 PM
