Samsung PN50B450B1D showing evenly spaced vertical lines
  • 205rogers
    • Oct 2018
    • 3
    When I first turn my TV on, it works fine for a few minutes and then the attached vertical lines show up across the screen. If i turn it off and back on same thing, works for a few minutes then the lines come back.
    I have read other posts about the T-con PWB. Not sure if thats the problem with mine or not. Hoping to get some advice. Thanks
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung PN50B450B1D showing evenly spaced vertical lines
    Do the lines cut through the menu box when menu button is pressed?
    • 205rogers
      • Oct 2018
      • 3
      Yes. They are always there.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Ok. Remove the ldvs cable that goes from the mainboard to the control board. Its usually a flat wire. On the control board there is 4 pins. Take a harddrive jumper( for choosing master, slave, etc.) and put it on pins 3 and 4. Plug tv in and look at the test patterns on the screen. If they look good your mainboard is bad.
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • visionbluedemon
          Help. Sony kd-65x85dj vertical lines
          by visionbluedemon
          First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
          Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
          tried blocking LC lines too, but same results
          is it lcd panel issue or tcon board issue?...
          07-25-2025, 04:56 AM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • Andriod
          LG 47LN577 with black fading horizontal evenly spaced lines
          by Andriod
          So, I have searched the internet for long, high and low and ended up here.
          As the title suggests; there are static repeating black-ish horizontal lines that start from the left and fades away at around 65% toward the right, meaning its length is more than half the screen. The lines are from top to bottom evenly spaced. I can see the lines on the test image, and on chromecast input.
          This is my first time investigating TV errors at this level, and my initial googling led me to believe it was the T-CON board, considering that it has a left-ish problem. But googling even...
          12-30-2020, 03:38 PM
