Sony KDL-40S5100
  • shadetreetrader11
    • Oct 2015
    • 230
    Re: Sony KDL-40S5100
    No voltage on pin 6 of IC6700 to GND pin of connector CN6701
      Check Transistor Q6400 to see if it shows low resistance (set meter to Ohm mode) between E and C.
      Check the DCV of the Q6400 E-B junction (Voltage between Base and Emitter) to see if it is being turned on or not, it should be OFF in normal operation.
      If Q6400 is ON it will take the Enable signal to GND.
      • shadetreetrader11
        • Oct 2015
        • 230
        r6405 12v on vcc side and 0v on protection circuit side
        r6407 0v on each side of resistor
        r6417 3.4v on each side of resistor
        0 volts on all 3 legs of Q6400
          Emitter leg is at GND so it should be 0V.
          Base is also at 0V, that means the MOSFET Q6406 is turned, so the Collector (Backlight/BL-ON, it is connected to the ENABLE pin of the IC through 0 Ohms resistor R6711) of Q6400 should be really high toward 5V.
          There is another protection circuit (page 70) that can also stop the Backlight/BL-ON from going high if it detect bad lamp (LD - Lamp Detect); Q6704, 6705 from latch circuit driven by Q6706, Q6706 will turn on if the LD Voltage is less than 10V but you do have 12V on the LD pin so that is OK.
          I need you to check the resistance between ENABLE pin and GND pin to see if it shows very low resistance (<100 Ohms) or not.
          • shadetreetrader11
            • Oct 2015
            • 230
            Pin 6 of IC to gnd pin measures 11.65k ohms
              So that does not look bad, I would try removing the Q6400 and see if the Voltage at the Collector (Backlights/BL-ON/ENABLE) will go up Or not when TV is ON. It has two protection circuits so we just have to narrow it down first to find out which one is keeping the Backlights/BL-ON/ENABLE low.
              • shadetreetrader11
                • Oct 2015
                • 230
                With Q6400 removed. 0v on "Backlight On Enable" located on connector CN6154. 0v on Pin 6 of IC. All three pads where Q6400 sits is 0v to ground.
                  I went back to look at post #3 and realize that you only have 1.15V on the bl-on pin (CN6154 pin 4), I expect it to be for than 2.5V.
                  Please verify that R6406 (470 Ohms resistor is OK), it is connected between BL-ON (pin 4 of connector CN6154) which feeds the Enable pin of the IC.
                  You may want to try this, put 330 ~ 470 Ohms resistor between 3.3V power supply pin and the BL-ON pin of the connector after removing the BL-ON wire that goes back to the main board first to see if we can get the Enable signal to go high, right now it is either the R6406 has gone high resistance or the latch circuit is ON which you will have to remove Q6704 (Page 70 of the service manual) to find out, something is holding down that Enable line to 0V.
                    • 12167
                    • U.S.
                    #29
                    Did you try unplug cable from powersupply to mainboard? if backlights come on then try firmware update/reapply.
                    • shadetreetrader11
                      • Oct 2015
                      • 230
                      With Q6704 removed there is 0 v on bl_on. R6406 is 470 ohms. So at this point I have both Q6704 and Q6400 removed.
                      CN 6154
                      2.08 Dimmer
                      0 Bl_on
                      1.59 Inv_err
                      gnd
                      0 Balancer_err
                      • shadetreetrader11
                        • Oct 2015
                        • 230
                        I seemed to have damaged Q6704 while removing it. The SMD Code is LF I think it's a 2SC3052 SOT-23 package. I was looking at some of my junk boards I have laying around and I can't find one with the LF code. I found one with a SMD marking 16 I think that is a BC 847B. Wondering if that will work? both npn and the base,col,emit are in the same position.
                          0 Bl_on: but you have a little over 1V before (#post 3) on that pin which is the receiving pit to receive the BL-ON signal form the main board.
                          • shadetreetrader11
                            • Oct 2015
                            • 230
                            Those voltages were all taken with the board in the TV and the connectors hooked up. I wonder if for some reason that voltage reading was coming from something else. If you think that transistor will work I'll solder it in and put the board back in the TV and try it.
                              I will not put that transistor in yet until you are able to get the Enable Voltage at the Enable pin of the IC.
                              So right now with all the board hook up all the Voltage at the pins you report in post 1 and 3 are still the same except the BL-ON pin 4 is now 0 instead?
                              That BL-ON Voltage is from the main board when TV is turned on, 1.15V is too low that is why I suggest you to use the resistor to simulate the BL-ON signal.
                              • shadetreetrader11
                                • Oct 2015
                                • 230
                                Installed the board on TV and again have 1.15v on bl_on. Ran a jumper from 3.3 stby and 680 ohm resistor in series to bl_on and the backlights came on. But when you look at the screen there's many vertical lines. Nothing changes if you connect coax to it.
                                  Sounds like the multiple problem on the main board.
                                  • shadetreetrader11
                                    • Oct 2015
                                    • 230
                                    So do you think there's something on the main board that is dragging the 3.3v down?
                                      At this point since you are able to get the light source to work then if the main board is OK, beside of sending too low of the BL-ON signal, the T-CON and the panel are OK then you should have good sound and video, if not then you have more than just bad BL-ON signal.
                                      If you study the service manual then you can see how the BL-ON signal is generated.
                                      • Mrfix71
                                        • Jul 2020
                                        I have same model and symptoms. Power on I get green light and clicking of relay. No sound or backlight. Voltages on the PWR supply look correct. Should have jumped on buying the main board when I saw it last week!
                                        I am going to print this thread out as it looks informative.
                                        Keep up the awesome work
                                          • 12167
                                          • U.S.
                                          #40
                                          Can you do a simple test? unplug cable from powerboard to mainboard, leave it off, plug power cord into powerboard, is there anything on the screen?
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
                                          • edugimeno
                                            Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                                            by edugimeno
                                            Hi everyone!
                                            I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                                            I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                                            This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                                            To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                                            I respected the polarity, positive to cathode of protecting diode
                                            So provided all...
                                            04-18-2024, 01:15 PM
