Samsung Plasma PS50C687 3D No Picture only Sound - Need help -
  • tomre
    • Sep 2018
    I´ve got a defective Samsung Plasma TV PS50C687 with sound but no picture.
    Findings:
    After removing the back cover I found a green led on the logic board blinking every 5 seconds.
    I´ve checked the power supply -stand alone- and found that all voltages seems to be okay (VSTBY and V5.3 about +5,26V, Vg=+15V, Va=+55V and Vs=+209V).
    Next I´ve checked the Y-Main board, the Y-Buffer board and the X-Main board.
    On the Y-Main board I found a lot of shorted transistors and on the Y-Buffer board I found a driver IC with shorts. On the X-Main board I didn´t found any shorted tranistors or blown components.
    What I´ve done:
    I´ve bought an new Y-Main, Y-Buffer and X-Main board.
    Before I´ve replace the boards (at the same time) I´ve checked the new boards for shorts. But no shorts has been found.
    But after switching the power on, I had the same problem as before: Sound but no picture and the led on the logic board blinks every 5 seconds.
    The Vs and Va voltages comes only up for about 1,4 seconds.
    I´ve checked the three new boards again for shorts but all transitors and drivers are okay.
    But as soon as I disconnect the flat cable between the logic board and the Y-Main board, the Vs and Va voltages comes up steady and the green "heartbeat" led on the logic board blinks every second.
    Now it´s also possible to adjust the Vsc voltage (-190V) on the Y-main board.
    Does any one have an idea and can help me?
    Thanks in advance, Tom
    P.S.: Sorry for my bad english.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung Plasma PS50C687 3D No Picture only Sound - Need help -
    Look on the Y-Main Bd. for test points marks Vsc + and Vsc - and a control marked Vsc Adj. Place the red probe of the DMM on the Vsc + and the black probe on the Vsc - and adjust the Vsc control to the required -190Vdc if necessary. However ther may be a problem wth the Logic Bd causing your problem.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
