Samsung Plasma PS50C687 3D No Picture only Sound - Need help -
  • tomre
    • Sep 2018
    I´ve got a defective Samsung Plasma TV PS50C687 with sound but no picture.
    Findings:
    After removing the back cover I found a green led on the logic board blinking every 5 seconds.
    I´ve checked the power supply -stand alone- and found that all voltages seems to be okay (VSTBY and V5.3 about +5,26V, Vg=+15V, Va=+55V and Vs=+209V).
    Next I´ve checked the Y-Main board, the Y-Buffer board and the X-Main board.
    On the Y-Main board I found a lot of shorted transistors and on the Y-Buffer board I found a driver IC with shorts. On the X-Main board I didn´t found any shorted tranistors or blown components.
    What I´ve done:
    I´ve bought an new Y-Main, Y-Buffer and X-Main board.
    Before I´ve replace the boards (at the same time) I´ve checked the new boards for shorts. But no shorts has been found.
    But after switching the power on, I had the same problem as before: Sound but no picture and the led on the logic board blinks every 5 seconds.
    The Vs and Va voltages comes only up for about 1,4 seconds.
    I´ve checked the three new boards again for shorts but all transitors and drivers are okay.
    But as soon as I disconnect the flat cable between the logic board and the Y-Main board, the Vs and Va voltages comes up steady and the green "heartbeat" led on the logic board blinks every second.
    Now it´s also possible to adjust the Vsc voltage (-190V) on the Y-main board.
    Does any one have an idea and can help me?
    Thanks in advance, Tom
    P.S.: Sorry for my bad english.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung Plasma PS50C687 3D No Picture only Sound - Need help -
    Look on the Y-Main Bd. for test points marks Vsc + and Vsc - and a control marked Vsc Adj. Place the red probe of the DMM on the Vsc + and the black probe on the Vsc - and adjust the Vsc control to the required -190Vdc if necessary. However ther may be a problem wth the Logic Bd causing your problem.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • slimmy182
      [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
      by slimmy182
      Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
      I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
      Looking on google I found this:...
      01-14-2023, 11:55 AM
