Adding fans to Panasonic Plasma
  • craftech
    • Mar 2006
    • 45
    Recently replaced SC and surrounding boards on a Panasonic TC-P42X1 due to standard 7-blink failure code. There are no cooling fans on that model. Searched the forum for a mod to add them, but didn't find one. Forgive me if I didn't look hard enough, but does anyone have any suggestions on how to do that. I have quite a few quiet computer case fans. Zip ties and a separate power supply blowing in maybe?
    Thanks,
    John
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Adding fans to Panasonic Plasma
    Yes you have all the required components to install fans in your PLASMA. I always add a gratis fan to my PLASMA jobs. Just make sure and set the air direction to extract hot air from the TV. I would normally take the 12-17Vdc from the PSU pin to close a relay that will turn on the fan, supplied with power from a small 12V SMPS.
    • craftech
      • Mar 2006
      • 45
      Sorry I didn't get back to this earlier. Forgive my manners.
      Thanks for the suggestion Andrew
        I added a fan to my TC-P42S30 after the SC board repair.
        The fan is powered off the F_15V line with a resistor that dropped voltage to 7V. This provides sufficient airflow whilst not being extraordinarily loud. I tapped off the 15V supply to the SC board so it would only be active when the panel was on.
        • r-p
          • Feb 2013
          • 44
          • Netherlands
          I often use the 5V powersupply which is normally strong enough (enough current capability to run a few extra fans) or indeed a 12-15V supply with some resistors. Not all 12V fans will run, or better not start up of off 5V.
          I use old computer-/server-fans, not really quiet ones, so I need to drop the voltage more to get them to an acceptable soundlevel compared to new quieter fans
          Two of my examples. In no way a perfect solution, but it may help to get ideas.
          A 60" plasma, never used them until a fault reappeared and the fault wasn't solved by the extra cooling.
          I did use a plug so the backplate can still be totally detached.
          42" plasma, known for overheating issues. So that is why I put them on the heatsinks themselves. Loads more work than the 60"above. They have several speed settings and it is a WII/XBOX monitor, so noise isn't that much of an issue.
          Link to moving gif.
          It won't show correctly when linking it as a pic and sorry about the speed being a bit high. Made this years ago and wouldn't know where to find the original pics...
          • jm1234
            Panasonic plasma TX-P42ST50 - 6 blinks
            by jm1234
            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
            I checked that board for any obvious faults...
            05-22-2024, 06:59 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • Eaglecrest
            Panasonic plasma color stripe
            by Eaglecrest
            I have a 50" Panasonic that has a color stripe that shows up much of the time. See attached picture, what could cause this?
            11-05-2025, 06:16 PM
          • Alicat
            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
            by Alicat
            Stopped by this site trying to fix my parents Panasonic Plasma TV.
            Model number is TH-50PZ85U
            Power comes on and the red power light stays on solid.
            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
            I also hear a few clicks.
            I also think my parents said there was a thunderstorm and the TV failed after that.
            Section 6 in the service manual talks about power and no screen,...
            10-30-2024, 10:09 AM
          • Lintesir
            Panasonic P42S30 Plasma - Pink sparkles
            by Lintesir
            My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
            There is about a 5cm high region at the top without any sparkles,...
            07-26-2024, 03:16 AM
