LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
  • JDC
    • May 2015
    • 273
    Make and Model: LG 60PB6650-UA
    Issue: Turns on, no backlight, can hear static (no channel)
    I've been repairing TVs for a couple years now. I know how to use a multimeter for the most part and know how to test most components for shorts.
    The power board connects to the ZSUS and then connects to the YSUS. The ZSUS is where I believe the failure is because the 16v line is only 3.8V, even when I disconnect the ZSUS from the YSUS.
    This particular model seems to have a common failure with its YSUS. My goal earlier was to prove the YSUS was bad so I could send it away for repair. Using CoppellTV's ebay auction repair kit as a guide*, I tested most of the components it lists in its kit (except for IC402, IC403, and IC100) and all were OK. For the 3 components mentioned, I contacted CoppellTV via ebay to get their advice about those components and they said that if Q401,Q402,Q404,Q405 and Q406 were good, IC402 and IC403 should be too. At this point I took a break.
    Today, I took some Zsus measurements and found that good VS, VA, and 5V power is getting to the board, but on the connection from the board to the YSUS, only 3.8v of 16v was leaving it.
    I've read the other posts on badcaps concerning this TV and recall someone else having this exact issue but no resolution (unless I missed something).
    I prefer not to randomly send boards off for repair. Any suggestions?
    * https://www.ebay.com/itm/REPAIR-KIT-...ss!26582!US!-1)
  • R_J
    • 9607
    Re: LG 60PB6650 - Bad ZSUS (3.8v to YSUS instead of 16v)?
    What voltage do you get on R232 (white ceramic 5watt) resistor on the Y-sus? this voltage comes from the same yellow transformer.
    I believe the 16 volts comes from that transformer, rectified by D203 (back of board) and goes through ic201
    I wonder if a bad buffer board might cause this.
    I see there is also 17 volts on the power supply board, but that feeds something else
      You need to identify if this is one of the LG sets that generates the 16V on the Y-sus, usually from the yellow transformer.
      Does the power board have a 16V output?
      • JDC
        • May 2015
        • 273
        CORRECTION: Its 18V. I read it wrong.
        .02.32 V for the resistor I'm not sure I did that right as the meter added the 0.
        The power board does not have a 16v output.
        • R_J
          • 9607
          That resistor is fed by the same transformer via diode D20? (next to D207) This circuit also supplies the VY voltage.
          Have you tried disconnecting the buffer boards from the Y-sus to see if the 16 volts comes up?
          BTW pin 1 & 2 of the power supply has +17 volts but goes to the main board, likely for Audio circuit.
          • JDC
            • May 2015
            • 273
            Ill try disconnecting the boards one at a time.
            • JDC
              • May 2015
              • 273
              No change in voltage from removing just the lower, then both, and then just the upper. 3.9v remains.
              Something else I noticed: if there is supposed to be a lit-up LED on the center board (Main logic board?), it's not there.
              • R_J
                • 9607
                Its hard to say about the led, when you first turn on the tv does it come on then go off? or does it never come on?
                It could be that the control board (main logic) is not working. If it is not working the Y-sus will not be geting drive and that could be whats happening.
                I checked the other threads on this model and it seems like the led should be blinking. I see reports of C873 blowing on the upper buffer board. and C975 on the lower buffer
                • JDC
                  • May 2015
                  • 273
                  No lighting up, nothing. Can hear static like it's not tuned to a channel. C873 and C975 aren't shorted so I'm stumped.
                  • R_J
                    • 9607
                    Well search your model "60PB6650" and there are other threads, and from what I can tell the control board led should come on and flash on and off,
                    • JDC
                      • May 2015
                      • 273
                      It's not, though. Hmmm....
                      • JDC
                        • May 2015
                        • 273
                        Any other ideas, folks?
                        • R_J
                          • 9607
                          Have you checked to see if you have any voltages on the control board? I see a couple regulator ic's IC264 (2.5v) and IC253 (can't see the number)
                          if you short the two pads labeled EXT_AUTO_GEN and plug in the tv does that change anything
                          • JDC
                            • May 2015
                            • 273
                            Done. No change.
                            • tvtimmy
                              • Mar 2015
                              • 1160
                              • usa
                              You have to unplug the ldvs cable from the mainboard also to test.
                              • R_J
                                • 9607
                                You can try disconnecting the cable from the main and do the autogen test, sometimes you can leave it connected, I was'nt sure if the cable from the main also supplied the supply voltage for the ctrl board or it came from the ysus, A lot of the control boards have a seperate cable for the supply voltage.
                                • JDC
                                  • May 2015
                                  • 273
                                  I'm assuming you mean the flat ribbon cable running from the main board to the logic board. I unplugged each cable of the 5 cables from the logic board one at a time and other than the 3.9V going up to 3.99 eventually, nothing has changed. Still hear static.
                                  • R_J
                                    • 9607
                                    It is starting to look like it could be the control board, like I said earlier, other people reported the led would pulse when the tv was on, even if there was a fault elsewere
                                    • JDC
                                      • May 2015
                                      • 273
                                      Thanks for your help so far. I'll keep bumping this thread in the coming days.
                                      • JDC
                                        • May 2015
                                        • 273
                                        Bump. Any help is appreciated.
                                        • PlasMatt
                                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                                          by PlasMatt
                                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                                          09-20-2025, 06:50 PM
                                        • Salvatore057
                                          plasma TV Lg 42w451 - why is the zsus igbts damaged when the ysus is plugged?
                                          by Salvatore057
                                          I am trying to fix my plasma TV which is not powering on due to damaged IGBTs. I have changed two igbts and 2 IC drivers on the zsus and also two igbts on the ysus.
                                          Now everytime I plugged the ZSUS and the YSUS boards to the power board, the two 30f124 IGBT on the ZSUS are damaged and the TV stays in standby mode. When I plug the ZSUS board alone the TV turns ON but I do not see pictures. When I plug the ZSUS board without the two 30f124 IGBTs and the YSUS board, the TV powers on with a picture.
                                          I am lost, should I change the YSUS board? Is the YSUS board damaging...
                                          04-29-2018, 01:29 PM
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
                                        • Truncatedhose
                                          Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                          by Truncatedhose
                                          Greetings all!
                                          Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                          Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                          07-04-2018, 10:59 AM
                                        • divingfe
                                          LG Plasma 50PA5500. Sound, no picture !!
                                          by divingfe
                                          Sorry if this is too repetitive, or in the wrong place.
                                          I'm new, and having much the same problem. My LG50PA5500 TV has been working flawlessly since new. The other day, while in the midst of watching a broadcast DTV channel, the entire screen suddenly and silently went dark (no snaps, crackles or pops); sound, channel selection and inputs all work OK.
                                          I have checked connections and voltages from: stdby, pwr supply board fuses, psb output voltages to Zsus board and its fuse, output voltages from Zsus to Ysus and its fuse. All precisely normal!! I've also checked voltages to the...
                                          06-19-2021, 06:36 PM
