Simulating load on LED drivers.
+ More Options
Posts
    Re: Simulating load on LED drivers.
    How would you connect the circuit provide by TOM to the LED driver board?
    The Cathode return of the LED is not connected directly to GND in the LED power supply board, it is connected to the PWM control and current sensing resistor to GND.
    • lookimback
      • Aug 2013
      • 1489
      I thought I'd be able to float the ground so the ground points in the schematic would be the cathode return. But, I'm guessing that I would have a problem with the logic ground not being at the same potential. But, if I measured the resistance from the cathode return to ground, and set the logic ground to the same potential, would that solve it?
      ------------signature starts here------------
        The way the LED driver circuits is set up is to have the PWM Controlled and sensing resistor on the sink side of the LED, Booted Voltage is fed directly to the Anode of the LED string.
          That is why I suggested the circuit should be powered from a battery.
          The circuit would respond quick enough to 100Hz PWM, possibly the feed forward cap around the op-amp would need tweaking but it should work ok as-is.
          • lookimback
            • Aug 2013
            • 1489
            So, how would I connect that circuit to the LED driver output?
              Between the + and - of the LED driver output, where the LED string would normally go.
              • lookimback
                • Aug 2013
                • 1489
                So, the battery current output to + and ground to - ?
                  Across the MOSFET between the drain and other end of the resistor.
                  You will want to modify that circuit of course.
                  Why don't you test it on the bench first. You should draw a schematic first.
                  • lookimback
                    • Aug 2013
                    • 1489
                    Yes, I'll have to figure out how much power this could potentially see and choose MOSFETs accordingly. Also a really big heat sink. When I actually get time to start this, which hopefully will be next month, I'll draw up a schematic post it. Definitely will bench test it. Another question: I'm assuming ISET is where I'd put a potentiometer to set it. Would the other side of that pot go to the other side of resistors R8/R9(between them and R10)?
                      ISET is a voltage input. So the pot would go across a voltage reference ideally. If you just use the battery as the reference then you may find the current changes as the battery slowly runs flat. One possibility is you could use a 5V regulator or similar as a reference source. The other thing you will need to do is make sure the current scale is set correctly. That circuit is designed for a fairly high discharge current of up to 1.5 amps. You probably only want a fifth of that, so you could look at changing some of the resistors. Finally, the circuit itself can actually be simplified by removing one of the op-amps, just have a Google for current sink circuits, it will be a little less precise, but it will work fine for your application.
                      • lookimback
                        • Aug 2013
                        • 1489
                        I'll add an LDO for the reference. I had saw a simple one with one op-amp before you posted this one. Would I still need the parallel MOSFETs if I'm sinking that much less current?
                          The parallel MOSFETs are used in this application to dissipate as much power as possible in a small area.
                          You can use one big heatsunk MOSFET or hundreds of SMD MOSFETs, it depends on what you want to do, but soldering hundreds of SMD MOSFETs doesn't sound fun to me .
                          • lookimback
                            • Aug 2013
                            • 1489
                            Be great if I needed practice, but I think I've mastered the technique already and want to have time for other projects and family as well. I think I'll go with the one big MOSFET.
                            • caspian
                              What Zener Diodes on a Linear Power Supply
                              by caspian
                              Dear members,
                              I have a linear variable power supply with unknown brand name that I used for voltage injection.
                              Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                              In addition, I discovered that its zener diodes are defective.
                              I can replace the burned transistors.
                              But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                              Therefore, I cannot replace the zener diodes.
                              I do not want to test the zener diodes in a test circuit to discover their model or value.
                              no schematics are available...
                              05-26-2025, 12:38 PM
                            • AJ847.63e
                              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                              by AJ847.63e
                              Hi Folks,
                              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                              05-06-2025, 10:37 PM
                            • Pipolups
                              Corsair K70 LUX RGB dying LEDs
                              by Pipolups
                              Hi there !
                              I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                              Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                              10-08-2024, 11:58 AM
                              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:20 PM
                              HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                              09-06-2024, 10:56 AM
