Yellow all,
Found this site researching all the havoc bad caps can cause. I seen the TV repair section and it appears there are many Knowledgeable folks on here. Maybe someone can point me in the right direction. I have a Zenith 32" crt set,
model# SL3285BG. When you first turn it on the picture is blue. After a while (and this time varies from 30 to 60 minutes), the picture will then be fine. So it seems that once the set warms up for a while the offending component starts working ok. This is the opposite of what I assume should happen (component heating up then failing). Any thoughts? Thanks!
