What is this component? on Sharp LG-46D64U
  • Icitte
    • Aug 2011
    • 61
    Trying to figure what is this component? Looks like a fuse/diode/resistor
    I want to know how to test it
    thanks a lot
    Re: What is this component? on Sharp LG-46D64U
    That is surge protection device, the TV does not need it to function. It will show open circuit when tested if it is still OK.
    The questions are:,
    1) What is the TV not doing?
    2) What Voltages have you test so far?
    3) We will need good clear pictures of the whole back side of the TV showing all the boards.
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • dj8452000
      How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
      by dj8452000
      I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
      02-18-2025, 08:28 AM
    • YellowJacket
      SHARP LC-32CHF5111K - stuck at color test mode
      by YellowJacket
      Hi friends,
      TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
      So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
      02-04-2023, 03:11 AM
    • MalodicOne
      macbook pro 820-02100 5v 0 amp
      by MalodicOne
      Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
      Tested all CD3217 and RAA489900:
      UF400
      PP3v3_UPC0_LDO- 3.48v, .473 Diode
      PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
      USBC0_CC1- 0v, .455 Diode
      USBC0_CC2- 1.66v, .454 Diode...
      07-25-2025, 10:49 AM
    • asr
      Finding replacement diode iPad Pro 3rd gen A1701
      by asr
      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
      07-09-2024, 06:24 PM
