I have a sharp lc-32sh130k tv which has switched itself off. Now when you press the buttons on the remote nothing happens. When you pres the buttons on the side they all beep and do nothing. Any ideas on how I can get this working or shall I just buy a different television next time?
Sharp lc-32sh130k
I have a Sharp LC-40LE431U TV. The symptoms are when plugged in, the control buttons on the right side panel don't seem to want to work correctly. I get a solid red light. But when I press the Power button, it does not power on immediately. I have to keep pressing ALL the side buttons randomly until finally the solid green light is on. Then when pressing each additional button, they do not always respond correctly, if at all. Pressing the Volume button might bring up the Menu, or vise versa. Even if I can get the Menu screen to come up and scroll through the selections, I still cannot select any...
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
does... -
by gavenbHi folks!
I have a LC-80LE661U that had some interesting issues.
Initially, it would come on and show the sharp logo and would show normal static before shutting off.
I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it... - Loading...
