Mitsubishi DLP wd65733
  • GAStuntman
    • Dec 2017
    • 65
    I have a DLP tv with no power light, no picture, or no sound. This is my first time working on this type of tv. The voltage on the power supply seems to be right? Any suggestions?
  • R_J
    • 9633
    Re: Mitsubishi DLP wd65733
    This is not much information... What are the voltages on the plug going from the power supply to the main? There should be a number of fuses on the main board, ie: F9G00, F9G01, either check that they are not open or check the voltage on both sides of them.
    • GAStuntman
      • Dec 2017
      • 65
      The fuses starting at F9G00, etc. all have voltage at 12.21
      • GAStuntman
        • Dec 2017
        • 65
        The connector in the picture below has the right voltage on the power supply cable as well as the mainboard side. As stated above the fuses all have the correct voltage as well. If you like at the picture it shows where the pins should test at a certain voltage. That's what I'm talking about when I say I'm getting the proper voltage.
        • R_J
          • 9633
          Does this set have a system reset button on the front panel? if not try this: Press and hold power button for 8 seconds
          Do you have any voltage going to the board with the power button?
          If the tv has a ACTIVITY button, press and hold the ACTIVITY and CHANNEL DOWN buttons at the same time and hold for 5 seconds, see if you get any led flashing a code
          • GAStuntman
            • Dec 2017
            • 65
            The reset button didn’t do anything. I also tried holding the power button for 8 seconds & still no luck. It’s like the tv is completely dead. None of the light indicators are working. I don’t hear any noises when I plug the tv into a socket or when pressing the power button. I have read that the back panel is supposed to be connected to the tv when testing for lights. I haven’t put the back panel back on yet. I wanted to test the boards before putting everything back together. Could this be my problem?
            • R_J
              • 9633
              There will be a lamp door switch that needs to be defeated if you try without the cover on. But if that switch is open it should give an error (lamp led blinks yellow)
              You must be missing one of the 3.3 or 5 volts, did you check for voltage on the cable that goes to the buttons?
              Look for F9G00 fuse, it supplies 12 volts to IC9G01 (pin2), its output should be 5VSL (5 volts) on pins 7&8. that should feed IC9C51 pins 8&5 (via L9g14 & L9G02 to L9C51) and output 3.3VSL on pin1
              • GAStuntman
                • Dec 2017
                • 65
                Thanks. I’m getting the voltage that you suggested above. I’m still checking other pins as of now but I started with the F9G00 fuse & so far so good.
                • GAStuntman
                  • Dec 2017
                  • 65
                  The voltage checks out on the pins you suggested. I must admiythis tv has me stomped. If you think it’s a mainboard issue I’ll just replace the mainboard instead of trying to repair the current one. I know the power supply is good. Do you think ording a new mainboard will fix the tv?
                  • R_J
                    • 9633
                    I never worked on too many of the mitsubishi' dlp's, there were'nt too many sold around here. I would do some more checks before ordering a main baord. Do you have the service manual?
                    • GAStuntman
                      • Dec 2017
                      • 65
                      Yes, I was able to find the service manual. I'm still trying to figure out what is causing the issue.
                      • budwich
                        • Jul 2015
                        • 3097
                        just like regular tv troubleshooting... you need to provide the readings and labels of ALL the pins that are shown... not just "voltages check out"... the forum can't see what you have done to say that. And just like regular tv troubleshooting... the values of the "other pins" are just as important even though they don't have "voltage labels" associated with them.... that's why you need the list of pins and measured values... with the set plugged in and then again with the set power button pressed. Then people may be able to help you get to the problem. Note: some of those pins may change during the power up "cycle" so you may need to monitor them during that event and repeat for each cycle and pin.
                        • R_J
                          • 9633
                          You may want to check around IC7A01, that is the main micro, Check that you have 3.3VSL on L7A01, that is the VCC for the micro.
                          KCS0 is the power button input, check voltage on R7AA9 and see if it changes when power button is pressed (one side connects to 3.3v other side goes to micro KCS0)
                          (page 82)
                            Surface Mount Fuses Fundamentals Datasheet
                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                            10-07-2024, 06:07 AM
                          • Sik_6ty_Sixx
                            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                            by Sik_6ty_Sixx
                            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                            02-18-2025, 05:06 AM
                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                            by sam_sam_sam
                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                            12-14-2023, 07:45 PM
                          • acedogblast
                            Power supply for main amp blows fuses after replacing filter caps.
                            by acedogblast
                            Hello I have a Marantz sr5012 that I have been repairing. After I have replaced the 2 main filter caps the 2 fuses for the power amplifier blows. The original capacitors are ELNA LAO 10,000uF 71V and the replacements are Nichicon LKS 10,000uF 80V.
                            I assume a short circuit connection has occurred so I set my multimeter to measure ohms across the 2 fuse connections and both read 55 Kilo-ohms so I assume that is ok.
                            I am certain that I do not have any bridges on my soldering and after probing around I do find a temporary 0 ohm reading when probing across the positive and negative...
                            02-27-2023, 05:11 PM
                          • MrzPdlch
                            Blown fuses on Gigabyte GTX 980TI 6GB
                            by MrzPdlch
                            Hey everyone,
                            I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                            Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                            Find some pictures of the actual GPU together with a picture of how it should look like.
                            I also wonder whther it might be a problem that there...
                            03-10-2024, 04:14 PM
