Samsung ue40D6100 Dead, no picture, boot loop
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Trouble in TVLand again This Sammy TV turns on the backlight but doesn't display anything. Moreover, it seems to be stuck in some sort of loop, because after a while it power-cycles. The guy said it quit on him when watching a movie from an HDD, so either the main board is a POS and died under load due to heat, or the firmware got corrupted. The main board is in the pictures...any ideas ? Should I hit that CPU with some hot air ? Is it even worth the trouble ? Cheers.
    Wattevah...
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Samsung ue40D6100 Dead, no picture, boot loop
    LOL.....sorted: blasted the board with some hot air, focusing primarily on the silver CPU and it's working now. It's not going to last - that's a no-brainer, but at least I know I was right in my initial diagnosis
    Wattevah...
    • viktorkane
      • Jul 2018
      • 32
      • albania
      hello
      change the mainboard
      • Takeatry
        Yet another Samsung QLED Boot Loop
        by Takeatry
        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
        10-04-2024, 02:57 PM
      • torchzack
        Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
        by torchzack
        Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
        I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
        Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
        08-28-2023, 07:42 AM
      • NolesFan
        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
        by NolesFan
        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
        10-24-2024, 06:36 PM
      • eigma
        Samsung UN40H5003 boot loop every ~8 seconds
        by eigma
        Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
        Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
        SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
        Main board: BN94-07592P / BN97-08922R...
        11-20-2024, 10:31 PM
      • blaster_
        Samsung UE49MU6105K - boot loop, horizontal lines
        by blaster_
        Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
        Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
        06-22-2022, 05:19 PM
