LG 50LA6970 Lightning Damage - Dead
  • martyparish
    • Dec 2012
    • 313
    Hi it's been a while since I posted. I haven't messed with TVs for a while now since they became so inexpensive.
    However, I just picked up this free 50", 3D LED smart TV that seems worth it. It's clean and has all its accessories included even 4 sets of 3D glasses.
    He told me the TV died after a thunderstorm and other equipment in his house died at the same time.
    I'm pretty sure it's the main board. I have 3.3v standby voltage and that's it. PWR ON is zero even when pressing the power button.
    My question is: Is there any chance on troubleshooting the main board and repairing it? They are expensive and there aren't many out there to buy. I've only found a couple of them on ebay and that is IT!
    What usually burns on main boards on a lightning strike? I do not see any visible damage at all.
    I attached pic of the main board.
    One last question: Do you think it's worth buying a main board for $160 for this set?
    Thanks!!!
  • Asraf Atb
    by Asraf Atb
    01-27-2025, 05:02 PM
  • _AcE_
    JBL Soundbar 2.1 Deep Bass PSU No DC Power Output (Detailed, w/ Schematics)
    by _AcE_
    I have two of these soundbars, both with the exact same issue. The soundbars were hit by lightning and no longer power on. The PSU does not output any voltage on the DC side. When plugged into mains, the DC output is a stone-cold 0.0 volts. The AC side of the PSU seems to be functioning correctly (as far as I can tell). When checking the plugged-in PSU with my thermal camera, the OB5269CP PWM controller (U1) and the two resistors (R12 and R13) pulse on and off. These run to the positive DC side of the bridge rectifier (among other components along the way).
    There's no physical damage...
    08-10-2025, 09:27 AM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • abajor
    A2141 minor liquid damage, U3100 TOP port dead. Periodically boots to 20V ~1A on other USBC ports
    by abajor
    Just wondering if anybody has seen this issue. I'm assuming that all of the CD3217's are semi functional for the chips to request 20V from the PSU.
    This unit had some soda spattered up into the side vent. I ultrasonic cleaned the board, now getting this weird sometimes requesting 20V behavior, then it goes back to 5.2V ~ 25mA The U3200 jack cycles.
    I'm hoping this is just an issue with some components between the TOP Jack and U3100 and not U3100 itself.
    Not seeing anything unusual on thermals just some of the power supply inductors getting warm when it's requesting...
    08-25-2025, 01:13 PM
