Samsung UE46F5000
  • sparks_cfr
    • Jun 2016
    • 7
    Samsung UE46F5000
    Hi All,
    Have been searching but can't find any mentions of the issue I'm having, which is odd, or I'm just been n00bish with my searching...
    The TV seems to be constantly rebooting, I see a double blink, followed by a single blink. I read on another forum that it's the mainboard, anyone have any ideas please?
    How can I test etc..
    S
    Re: Samsung UE46F5000
    Can we at least see some pictures of the whole backside of the TV showing all the boards?
    What is the history of the TV?
      09-07-2024, 05:50 AM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
    • plytek
      Samsung QE50Q60TA rebooting
      by plytek
      Hi all.
      I'm trying to fix my Samsung QE50Q60TA TV.
      IT's rebooting every few seconds.
      I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
      Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
      Can anyone suggest what I can test and do to get it working again please?...
      02-08-2025, 06:02 AM
    • unimatrix93
      SAMSUNG UE55TU7002KXXH rebooting
      by unimatrix93
      Hello everyone, I'm working on a Samsung TV that constantly rebooting.
      MB/PSU unit: BN9654185QE
      It loads up to the main menu then as soon as the backlight goes brighter it reboots.
      First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
      Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
      Also I have to note, that the MB/PSU combo gives out a very noticible...
      04-07-2025, 09:49 AM
