Phillips 55PFL5601/F7 - No Standby, No Power, Fluctuating Voltages...
  • grimacelord
    • Jan 2017
    • 377
    Re: Phillips 55PFL5601/F7 - No Standby, No Power, Fluctuating Voltages...
    Originally posted by budm
    1) So are they 0.5, 0.4, Ohms, K Ohms, M Ohms.
    2) What resistance scale do you have the meter on: 200 Ohms, 2K Ohms, 20K Ohm, etc.
    3) What did you use for GND for the meter?
    It is impossible to all 3 power supplies output showing <1 Ohm.
    It's an auto-ranging DMM by Klien Tools: https://www.amazon.com/Multimeter-Au.../dp/B018EXZO8M
    I used the J622 jumper labeled GND in the same area as the ones you wanted to check. Should I not have used that? There are other GND points in the general area of the board. I'll try it from another.
    Could my meter's battery need replacing? When I get back to work, I'll take readings of the same jumpers again just to make absolutely certain that is what my meter reads.
    Hell, I'll grab another meter that I have too in case something is weird about this one. I'll report back in a couple of hours.
    • grimacelord
      • Jan 2017
      • 377
      Alright. Took new readings and had my wife take some pictures. Unfortunately, it's not much different than what I got last time.
      I apologize for the blur, but it shows what it was intended to. Black probe on J622 GND, red probe on J620, J621, J623 respectively. These are the readings I get.
        At this point I think there is something going on with your meter.
        Try taking the resistance reading on one of the 3 diodes (they are sitting in parallel with each other right next to the big yellow transformer.
          BTW, do you also have some resistors, especially low Ohm one that you can check with your meter to see what it will show on your meter.
          The batteries indicator on the meter, does it show the battery symbol when battery is good or when it is bad? See user manual if you have it.
          • grimacelord
            • Jan 2017
            • 377
            I took a resistance reading of one. When it first put the probes, it started around 2 Ohms and steadily increased. Removing the probes and placing them back on the diode, it resumed from wherever I took the probes off at last, but this time, it decreased. Normal?
            Yes. This meter does show a low battery indicator, but it only lights when the battery needs to be replaced. It is not currently lit.
            Also, I don't have any spare resistors at the moment.
            • grimacelord
              • Jan 2017
              • 377
              I pulled out another DMM I have and took readings of the same jumpers. Same readings.
              I mentioned in the original post that I bought both main board and power board replacements. The replacement boards are doing the exact same thing that the original boards were.
              When I fully connect all cables between all of the boards and plug in the power, I hear that pulsating buzzing sound coming from one of the transformers on the power board. On your advice, I discovered that unplugging the main cable to the main board causes this sound to stop. Both main boards I have are doing this - the original one and the replacement I purchased. What are the chances of that?
              The only thing remaining consistent is that main cable between the two boards. Could that be responsible for what I'm seeing here?
                OK, if you disconnect the cable between the power supply and the main board then test those 3 jumpers again to see what resistance you will get, you were getting around 13 Ohms before so I cannot see why it went down to <1 Ohm, something is not making sense to me right now.
                • grimacelord
                  • Jan 2017
                  • 377
                  Alright, with the main board disconnected and all other boards and cables still attached, here are the resistance readings of those 3 jumpers:
                  J621 56.5 K Ohms | (Second reading about 3 minutes later) 56.6 K Ohms
                  J620 36.9 M Ohms (and rising)| (Second reading about 3 minutes later) 2.24 M Ohms and dropping
                  J623 3.0 and climbing | (second reading about 3 minutes later) 0.8 and dropping
                  The second reading on J623 above seemed to resume declining from the initial reading of around 3.0 Ohms I got. J620 was weird, it initially read 36.9 but after holding the probes there long enough, the DMM auto-ranged itself down to around 2.2 omhs and dropping.
                  Using my other DMM: Here are the readings of the same jumpers with a different DMM:
                  J621 56.6
                  J620 30.5 and climbing
                  • Cemal Odabasioglu
                    MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                    by Cemal Odabasioglu
                    I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                    Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                    Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                    Observations...
                    01-14-2025, 03:54 PM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • triplefour
                    ONN 100012588 Has fluctuating Voltage on PSU 12v
                    by triplefour
                    Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                    anyway i go to this guys house to look at an ONN 100012588
                    this is my first time looking at one of these brand of TV's.
                    TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                    09-14-2022, 07:41 PM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • Crystaleyes
                    Samsung BN44-00259A standby question
                    by Crystaleyes
                    Hi all.
                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                    08-11-2023, 05:15 AM
