LG 40UB800V takes long to turn on
  • mitsukiso
    • Sep 2017
    • 31
    • Италия
    as said, TV takes long to turn on when cold. warmer it gets - faster it switches on. Capacitors are checked, they are ok.
    maybe it's a strange idea but could it be resistors that work normally only when they are warm? some of resistors checked show me more resistance (sometimes even twice) than should according to color codes. have never checked them, have no idea if it's a normal thing
    thank you!
    by the way, powerboard is EAX65942801(1.6)
    thank you
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 40UB800V takes long to turn on
    This is often a sign but not always a sign of capacitors needing to be changed. Use a hair dryer on the power supply and warm up the capacitors to see if you can find which one may be affected.
    • mitsukiso
      • Sep 2017
      • 31
      • Италия
      what must a defective capacitor do being warm?.. sorry for stupid question, i'm a newbe
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        It's internal resistance drops allowing it to charge up to it nominal voltage.
        • ratoesan79
          Macbookpro 2015 not turn on after long sleep
          by ratoesan79
          Greeting..
          After a long sleep, my macbook pro 2015 a1502 won't turn on.
          When it is charged, it can be seen that the light is green then orange, but with SMC Reset and NVRAM both cannot also solve this problem.
          After I opened the bottom cover, I saw the fan spinning for a short time for about 1 second when the power button was pressed
          guess what I should check first,
          Oh I already have the scheme, it's just that I don't know where to start the inspection?​
          01-06-2025, 08:52 AM
        • Rinxx
          Need Help Reparing Ants infested Macbook
          by Rinxx
          Hello guys. So, I bought this "dead battery" Macbook Air 2015 A1465 hoping to make it good enough for personal use.
          When I got home, it turned on right away but indeed, battery was stuck at 1%. But after around 5 minutes it died and wont turn on again, no lights on charger.
          Opened the laptop, lots of ants inside, cleaned it up with isopropyl alcohol. Found that PPDCIN_G3H_INRUSH capacitor was shorted, so replaced it and re-assemble it.
          Laptop turns on fine for about 15 mins, did a reset and while reinstalling Macos, the laptop became intermittent, charger...
          08-12-2025, 10:54 AM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • jagg
          Laptop MSI-16k5 Board model MS-16k51 V1.1 takes a long time to send video
          by jagg
          Hello, the laptop It turns on and off several times, it takes a long time to send video, possibly it is bios?
          Here are the bios and the schematics.
          Could someone help me verify that the bios is correct? thank you so much !!...
          11-22-2023, 03:36 PM
        • redbaron1007
          Onkyo HT-R510 turns on and then immediatly off
          by redbaron1007
          I picked up an Onkyo HT-R510 that when I plug it in and press the power button will turn on and then a couple of seconds later turn itself off. When it turns on you can hear the relay click and then immediately click again and shut the power to the system off. I spent about 5 hours today trying to troubleshoot it and I did make some progress that may not actually tell me anything. It's still not really working and I'm not quite sure where to go next.
          Here's everything I've done so far.
          The first thing I did was open it up and check for any burn marks exploded parts...
          11-14-2021, 09:55 PM
