Macbookpro 2015 not turn on after long sleep
  • ratoesan79
    • Jan 2025
    • Indonesia
    Greeting..
    After a long sleep, my macbook pro 2015 a1502 won't turn on.
    When it is charged, it can be seen that the light is green then orange, but with SMC Reset and NVRAM both cannot also solve this problem.
    After I opened the bottom cover, I saw the fan spinning for a short time for about 1 second when the power button was pressed
    guess what I should check first,
    Oh I already have the scheme, it's just that I don't know where to start the inspection?​
  • Rinxx
    Need Help Reparing Ants infested Macbook
    by Rinxx
    Hello guys. So, I bought this "dead battery" Macbook Air 2015 A1465 hoping to make it good enough for personal use.
    When I got home, it turned on right away but indeed, battery was stuck at 1%. But after around 5 minutes it died and wont turn on again, no lights on charger.
    Opened the laptop, lots of ants inside, cleaned it up with isopropyl alcohol. Found that PPDCIN_G3H_INRUSH capacitor was shorted, so replaced it and re-assemble it.
    Laptop turns on fine for about 15 mins, did a reset and while reinstalling Macos, the laptop became intermittent, charger...
    08-12-2025, 10:54 AM
  • pajdek
    Lenovo Y700-17ISK turn on and off
    by pajdek
    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
    09-20-2023, 02:49 AM
  • survivalbloke
    Lenovo Flex 5 14ITL05 - will only sleep if commanded to through start menu>power icon
    by survivalbloke
    This laptop refuses to sleep unless specifically commanded to sleep through Windows. If I close the lid, the screen does go dark just before the lid is closed, so it appears the hall sensor works. However, it will sit there, drawing 1.xx amps until the battery dies. If I command it to sleep, it drops down to normal sleeping current. If I have it sleeping with lid closed and I disconnect the power adapter, it will wake from sleep, even with the lid closed. I have updated the firmware, but still the fault persists. I've also verified power settings in Windows that the device is to sleep when the...
    03-20-2025, 02:29 PM
  • JRade
    MULTIMEDIA car radio CD:98067084XT CITROEN BERLINGO 2015 YEAR. DOES NOT TURN ON THE DISPLAY
    by JRade
    display:9801219480-01
    The button for turning on the device does not respond and the display is black - there is nothing. I have given a description of the measurements in the picture, only the voltage on the white wire is sometimes 5V and sometimes it is 12V. Only the background light on the device works when the position is turned on. The customer says that the display works occasionally and then the device works normally.
    Please help me, what should I do next?
    Greeting!
    05-25-2025, 01:29 PM
  • masoksian
    Dell latitude e7470 not turn on .power buton on off and Run Power problem
    by masoksian
    I am dealing with the problem of turning on and off my Dell e7470 notebook.
    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
    The system does not turn on, there is no post.
    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
    The problem continues in the same way.
    I tried to turn on the Fn key, nothing came to the screen....
    02-15-2025, 12:08 PM
