Hi. I have a Sharp Aquos LC-52LE700UN and it will not power on. When I first plug the set up, I get the green power light for about 2-5 seconds, then the OPC and power LEDs flash together once, then the Power LED blinks once, then the OPC and power LEDs blink again together, and the cycle continues but the set will not turn on. I hear a little click when I press the power button from inside the tv but doesn't turn on. If anyone has any experience with this problem with this particular set your help would be greatly appreciated. Oh yeah, the set would not reset either using the volume down and input method either. Thanks in advance.
Sharp Aquos LC-52LE700UN OPC AND POWER LEDS BLINKING WON'T TURN ON
Tags: None
Re: Sharp Aquos LC-52LE700UN OPC AND POWER LEDS BLINKING WON'T TURN ON
There's a manual with some details available from
https://www.manualslib.com/download/...32le700un.htmlWilling to help but I'm no expert.Comment
by olegeislerGot this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
Symptoms :
When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
A press on MENU as per the manual changes this to one short blink, one long and then repeats.
Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
As I see it mainboard has some kind of life, but does not... -
by scubacamperI found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by jonah1024Hello!
I'm a few days old into this TV screens repair universe so please bear with me.
Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
- I did the classic unplug and hold power button to discharge the caps but it didn't help.
- I did a factory reset as well...5 Photos -
by bajdikHello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?07-21-2023, 09:05 AM
- Loading...
