LA52A610A red standby light constant, clicking on and off
  • syaoran123
    • Jun 2014
    • 178
    LA52A610A (LA52A610A3F)
    Wont turn on, red standby light constantly on, clicking on and off relentlessly (2 sec on, 2 sec off)
    Power supply voltages are all there during the ON phase of the clicking cycle. I know the power supply is working because I have a working a650 which use identical power supply. See below solved thread.
    https://www.badcaps.net/forum/showthread.php?t=70831
    So that narrows it down to the mainboard. The a610 mainboard also looks the same as the a650 as shown, although couldn't find any shorts like i did on the a650. Could this be a bricked EEPROM issue that's causing constant standby light? And would anybody know where the EEPROM is?
    Note : i tried changing the capacitors on the mainboard already as you can see. Also the LA and LN lineup use different boards.
  • syaoran123
    • Jun 2014
    • 178
    Re: LA52A610A red standby light constant, clicking on and off
    Please help if somebody knows!
    I located two 8 pin ics that could possibly be the eeproms. One of them reads S24CS0 and the other reads ATMLH834. When I replaced both of them with new eeprom chips, I get the same thing. Still solid red standby light and clicking on and off, no picture, no backlight. The mainboard is very hard to find, so i need to repair it rather than replace.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      If they were both EEPROMS did you reprogram them first?
      • syaoran123
        • Jun 2014
        • 178
        No, they were not preprogrammed. I soldered in a new blank EEPROM.
        Are you saying these have to be pre-programmed, and not automatically written on start up? Are the above symptoms characteristic of a faulty EEPROM?
        Cheers
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          For your set I do not know. Some models will reprogram their own EEPROM but I don't believe that this is the case in all models.
          https://wiki.samygo.tv/index.php/UnB...Reset#LAxxC650
          • syaoran123
            • Jun 2014
            • 178
            So I tried replacing my A610A board with the A650A board from another working TV. The tv now works normally EXCEPT the standby light flashes repetitively while the TV is ON. The red light should turn off when the TV is on, well that's how it behaves on the normal working TV. It responds to remote commands though.
            Will try transferring the standby light and remote receiver module across to see if it stops the blinking.
            • syaoran123
              • Jun 2014
              • 178
              FYI: I entered the service menu>option and changed the model option to another one. This solved the flashing standby light issue.
              • Michael Long
                No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                by Michael Long
                I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                Dead / No Power / No Standby Light results after power company had three
                consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                09-13-2022, 06:55 AM
              • noinimod
                Sony 55X900E no standby light, no power. Replaced mainboard already
                by noinimod
                No standby red light, nothing
                This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                Disconnected JK3 power board from main board, checked voltages on all the pin outs
                At a few pins I can see the power supply providing 19.5V to the main board
                Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                12-22-2021, 12:58 AM
              • B0r1s
                Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                by B0r1s
                PSU - BN44-00878A
                Symptoms:
                The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                A weak clicking sound was coming from the transformer.
                Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                Progress:
                After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                01-17-2023, 04:58 PM
              • stylishconsultant
                un60j620dafxza - Samsung No Display Problem
                by stylishconsultant
                Hi All,
                Need help.
                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                09-04-2024, 03:26 AM
              • AleMonti
                LG 55EG910V - no power and no standby light
                by AleMonti
                I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                After checking the basics I did the following:
                • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                11-04-2024, 05:02 PM
