LG 50PA6500 won't turn on, clicking noise, replaced cap and still nothing
  • brybell
    • Jul 2018
    As the title says, I was watching TV and it randomly turned itself off. I turned it back on, it went out 10 seconds later. I turned it back on, head a loud pop/crack and picture went out.
    I tried turning it back on and I hear the click and the slight buzz like it is about to show a picture, but then nothing will happen.
    I did some reading here on multiple threads about this TV, and saw a lot of people replacing a thin-film cap on the power? board (the one in the middle of the TV) but that did not help the problem.
    I am trying to do some more research to diagnose the problem, but a little confused by the Y-sus, Z-sus, buffer boards etc. I was wondering also if this could be a simple fuse replacement? There are a lot of threads here about this TV, but none that seem to match my exact problem.
    I bought it brand new in I think 2013 or 2014. Would love to fix as it is our main TV, and I spent about $800 on it back then, but not sure if it is worth investing hundreds in for new boards.
    Any advice or tips are greatly appreciated. Thanks for looking!!
  • brybell
    • Jul 2018
    Re: LG 50PA6500 won't turn on, clicking noise, replaced cap and still nothing
    Any insight here?
      Probably a bad buffer board caused by panel (PDP) failure
      Try removing the top buffer board. If you see part of a picture or noise then it is definitely a bad top buffer board.
      • brybell
        • Jul 2018
        Thank you, I will check this today.
        • NConstantinou
          HP Z840 workstation power supply clicking noise
          by NConstantinou
          No power
          i have the above ps which i change the TOP258eg ic.
          Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
          i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
          the colours look like R,R,W or silver,G Bl.
          Thanks...
          12-25-2024, 02:24 AM
        • tony359
          by tony359
          11-28-2023, 05:18 AM
        • MegaZAC
          Onkyo TX-SR805 noise in one channel
          by MegaZAC
          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
          There's some logic behind it. As soon as I select an input I get only left...
          04-23-2025, 10:09 PM
        • B0r1s
          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
          by B0r1s
          PSU - BN44-00878A
          Symptoms:
          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
          A weak clicking sound was coming from the transformer.
          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
          Progress:
          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
          01-17-2023, 04:58 PM
        • courtcircuit
          Philips HTS8000 home cinema noise problem
          by courtcircuit
          Hello
          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
          Removed each of tyhe boards
          02-08-2025, 08:22 AM
