LG 49LB5550-UY with backlights that flicker on and off
  • SdlewisSr
    • Oct 2015
    • 146
    Re: LG 49LB5550-UY with backlights that flicker on and off
    Originally posted by Andrew F. Ali
    Those caps should be replaced. Is the BL-ON signal stedy when the Backlights are flashing? I still suspect bad LED backlight strips.
    Yes. DRV-ON is steady at 3.31v
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      This is a bad backlights issue is what you have. Of course the troubleshooting advice given by the other experts is actually what is done prior to opening up the Panel.
      • SdlewisSr
        • Oct 2015
        • 146
        Thanks. I am waiting on my LED tester to arrive today and I will check the backlights.
        • SdlewisSr
          • Oct 2015
          • 146
          I got my LED tester in. I LOVE IT!!!!! The LED's work just fine. The tester ran one LED string at 132v and the other at 92v. My guess is that the LED driver voltages are too high and cause the LED's to flicker. The customer decided to just replace the PSB/LED Driver.
          Thanks for all the help!!!!
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            You have to be a bit careful when using the led tester since it doesn't drive the leds at full current and therefore led's which may break down at a higher current than the tester can provide won't be found. However it is a useful tool to do preliminary testing.
            • SdlewisSr
              • Oct 2015
              • 146
              I did notice that on one LED string just before it settled at 92v, there was a single flicker.
              I will probably have to replace the LED's.
              Thanks!!!
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                #27
                Replace all the strips to be certain. I think replacing the LEDs will solve your problem.
                  Is your panel model LC490DUE-MGA6?
                  http://www.shopjimmy.com/lg-6916l-19...-10-strips.htm
                  • SdlewisSr
                    • Oct 2015
                    • 146
                    Originally posted by budm
                    lc490due(fg)(a6)
                    • SdlewisSr
                      • Oct 2015
                      • 146
                      Shop Jimmy is out of those and suggested an equivalent, which I ordered.
                      http://www.shopjimmy.com/lg-6916l-17...-10-strips.htm
                      • SdlewisSr
                        • Oct 2015
                        • 146
                        Just an update.
                        I replaced the backlights. There were four out on one string and three on the other. I received a replacement PSU/LED Driver Board from ShopJimmy, but it was behaving just like the original. The LED driver voltages were lower, but still fluctuated the same. They are sending me another board.
                        • SdlewisSr
                          • Oct 2015
                          • 146
                          A final update for this thread. (PROBLEM FIXED)
                          ShopJimmy sent me another PSU/LED Driver board and it also behaved like the original board.
                          I ordered a Complete TV repair Kit (Main board, PSU/LED Driver board, T-Con) from TV Parts Central. I installed all three boards and tested the LED Driver voltages without the LED strips connected and got the same voltage fluctuations as the original and ShopJimmy PSU/LED Driver boards.
                          I returned all the boards and both ShopJimmy and TV Parts Central said the boards tested good. I can only assume that the fluctuations without the LED strips connected are normal for this PSU/LED Driver board.
                          At this point I figured that there could only be one last place to look, seeing that I replaced the backlights, PSU/LED Driver board, Main board, and T-Con.
                          I took the panel apart and inspected the wires connecting the LED Driver with the LED strips. The wires showed signs of excessive heat where they passed through and contacted the panel. Evidently when the voltages got above 147v on one side and 98v on the other (these are the highest voltages the LED tester would apply to the LED strips) they were shorting causing the LED's to flicker. I insulated each wire where they passed through the panel and the LED's stopped flickering and worked as normal.
                          The LED Driver voltages with the LED's connected and working were fluctuated from 136v - 138v on one and 88v - 90v on the other.
                          When I checked the backlights level in the settings, it was at 80 (out of 100).
                          I dropped the setting down to 30. This is where I began to notice a dimming of the screen brightness.
                          I appreciate everyone's input!!!!
                            Thanks for the follow-up on the repair.
                            Did you take the pictures of the wires?
                            • SdlewisSr
                              • Oct 2015
                              • 146
                              I'm sorry. I didn't even think to take pictures of the wires.
                              • neilc6
                                • Nov 2015
                                • 1550
                                This is a big pain for those selling used boards on ebay. I put it clearly in my listings that backlight failure is common in certain models and to test the backlights before replacing the power supply board. Buyers will say the board is defective and the seller is forced to refund with ebay's money back guarantee.
                                • fixit007
                                  Samsung flicker - BN44-00932T board or else?
                                  by fixit007
                                  I picked up this TV that the prior owner said - just died.
                                  Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                                  Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                                  Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                                  05-04-2024, 06:14 PM
                                • pb1911nt
                                  MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
                                  by pb1911nt
                                  Hello forum,
                                  I'm still relatively new to the world of electrical repairs.
                                  I have a Macbook here that I can't figure out
                                  When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
                                  I removed the logic board and took a few measurements.
                                  But I can't really figure it out.
                                  At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
                                  09-07-2025, 11:35 AM
                                • jesterace
                                  Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                  by jesterace
                                  Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                  However, I am in a dilemma.
                                  I tested the backlight outputs with the lights disconnected...
                                  10-20-2024, 10:15 AM
                                • htv239
                                  LG UH8500 Backlight Troubleshooting Help
                                  by htv239
                                  I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                  Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                  What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                  10-11-2021, 01:53 PM
                                • Storyteller12
                                  Vizio M801D-A3 backlights flicker
                                  by Storyteller12
                                  Need a little help here.
                                  the backlights flicker when watching tv. Everything else works as it should. Also it's not the picture that's flickering just the leds.
                                  I tested the leds and all light up and measure 77.5v volts. I took the tv apart to double check leds and they all work and light up perfectly.
                                  I believe it's the power board causing the issue however I cannot find a replacement board so I'm stuck to finding the bad component. The power board has a sizzling sound coming from the backlight transformer. I replaced that and problem persist....
                                  05-25-2021, 11:17 AM
