Magnavox 50ME314V/F7 Question
  • Rmasters3
    • Mar 2010
    • 126
    Fires up and works in full screen but after 20-30 minutes goes to small screen with about a 6" black area surrounding the image. Still works, just lots smaller as if it was a 37-40" in a 50" display. Audio is fine.
    Just guessing: T-Con board, maybe main board as secondary place for the problem.
    Any input appreciated.
    Checking this out for a friend, I'm not much of a technician, and haven't eyeballed the boards.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Magnavox 50ME314V/F7 Question
    Main Bd. issue. Probably a software issue. Try an update. Before all that though check picture size setting and see if it is set at 4:3 ratio.
    • Rmasters3
      • Mar 2010
      • 126
      Thanks.
      • tonybig10
        Magnavox MDR515H/F7 And Magnavox MDR537H/F7
        by tonybig10
        Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
        the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
        03-07-2025, 01:03 PM
      • Joesev414
        Please Help! My Magnavox 50ME314V/F7 Beeping From Power Board
        by Joesev414
        Before getting to the problem, I am not an electrical engineer by any means but I really want to learn component level testing/trouble shooting and I do my best to pick things up quickly, that being said...
        I have a Magnavox 50ME314V/F7 (the Model of the boards are "BA4GU5G0201 2". The power board beeps when it is plugged in and when the CPU board ribbon cable is plugged in.
        I have replaced the 2 components with the red stars in the attached photo "PB TOP - Full". But it still beeps when powered and connected to...
        07-06-2018, 03:55 PM
      • sudz28
        Magnavox 27MS5402/17 CRT - no picture, flashing green light
        by sudz28
        I'm going to assume my beloved Magnavox CRT is toast, but also figured maybe this was a good opportunity to dip my toes into he circuitry waters and maybe learn something new. Also, I don't want to trash it if it's a fairly cheap/easy fix!
        My 20-year-old Magnavox has gotten me and my kids through many a gaming console change and worked great up until the other day. Following a long distance move, it sat in our garage for a year and now that I brought it in and turned it on I get no picture; instead, a green light blinks on the front of it; 7 flashes, one long flash, then 3 more...
        02-08-2022, 10:09 AM
      • barrybahr
        Magnavox 32MD350B/F7 getting a false on/off control voltage
        by barrybahr
        The unit is stuck in an intermittent on/off cycle. When I plug in the power cord, the green "On" light activates without any command, flashes for a few seconds, then turns off. The red standby light comes on for a few seconds before the cycle repeats. During this time, I cannot turn off the unit manually; it will shut off automatically after about five minutes, and there is no picture. Occasionally, with repeated attempts to power it on, I eventually get a picture and sound, which function properly. When it does work, I measure several voltages, and they appear to be normal....
        04-20-2025, 10:30 PM
      • pabloroggeri
        Magnavox MCS225/77 Replacement for UTC1316 or KA2214
        by pabloroggeri
        Hello guys. I need a replacement for UTC1316 or KA2214, in my country I can't get either of them, it is for an inexpensive radio recorder, there is no point in searching for it on e-bay or Amazon. Thank you
        08-28-2024, 10:34 AM
