LG YSUS EBR73575201 - need schematic and repair kit.
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi guys,
    I got in this plasma tv with that was tampered and i dont trust all those mosfets and diodes that are soldered in by someone. Is there somebody with a schematic on this board?
    I also noticed the KF7N60F is short circuited that is mounted on the heatsink on the top side. I am afraid to buy these parts from China. They charge $2.75 for 10. Sounds too cheap to be original spares but rather fake parts. Shop Jimmy has also blocked all incoming internet connections from our country because they have fraud issues so thy block every body. If you want to buy its thru ebay.
    Regards
    Angelos
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG YSUS EBR73575201 - need schematic and repair kit.
    Trust me. As long as someone went in there before and you are unaware of what the did or didn't do and to top it of you don't have a schematic I would suggest looking for a replacement board. You may end up spending monies that could be dead money.
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Those boards cost about $99. Too expensive for me. Is there anybody with a schematic???
      • flocko
        • Nov 2012
        • 1121
        Normal parts used for repair on these boards ( EAX 64286001 )are Q703/4/7/8+9 = RJP63K2 ,RJP30H2A and 20N60. details taken from my repair log book sorry no schematic hope this is of help Flocko
        • angelos
          • Dec 2012
          • 573
          • South Africa
          I recognise all the parts except the 20N60. Where does that chip come from. Position number?
          • flocko
            • Nov 2012
            • 1121
            Q709 is mounted on the heatsink others are SMD on the bottom of board,also check gate resistors to the above
            • cuhphniv
              • Jul 2018
              did you find the schematic, Angelos ? I also have LG 42pn4500 , the Y-SUS board make my PSU shut down (?) when I connect the cable from PSU to Y-SUS. Please help anyone
              • rmfar
                • Nov 2019
                • 3
                • Philippines
                I have the same problem, and i need also schematic for the board EAX64286001. thanks
                • rmfar
                  • Nov 2019
                  • 3
                  • Philippines
                  I have the same problem, and i need also schematic for the board EAX64286001. And tha part number or IC703, i found it shorted, does anyone has the clear copper side components values or part numbers? Thanks
                  • rmfar
                    • Nov 2019
                    • 3
                    • Philippines
                    In my testing/checking MOSFETs out of the circuit from these boards Y-sus using Multi-meter, when the gate is charged, why some MOSFETs (N-channel & P-channel), the drain to source let us say 0.002 or less my meter reads, others starts with more higher like 0.435 and running up as fast as a second or half a second until showing infinite? Discharged test is working (no reading on drain to source). What does it mean? Does all MOSFETs behave like that?
                    • tharusha2003
                      • May 2020
                      • Sri Lanka
                      Please give me code of this IC.
                      • kiko1
                        • Apr 2016
                        • 48
                        • croatia
                        30F131 are not orig. IGBTs for this board.
                        RJP63K2 2pcs. and RJP30H2 2pcs.
                        • PlasMatt
                          LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                          by PlasMatt
                          I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                          09-20-2025, 06:50 PM
                        • TinkerTron
                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                          by TinkerTron
                          Hey everyone,
                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                          Instead, here's what's been bugging me so far:
                          The schematic...
                          03-06-2025, 02:03 PM
                        • atunguyd
                          Acer x163w Monitor PSU schematic
                          by atunguyd
                          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                          03-05-2025, 02:08 PM
                        • Thetechdude
                          MSI Ventus RTX 4080 16G Broadview schematic needed
                          by Thetechdude
                          Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                          I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                          Thanks.
                          07-15-2025, 11:15 AM
                        • ianpoultonknights
                          Zenbook Flip 15 UX562AI schematic
                          by ianpoultonknights
                          Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                          06-26-2025, 02:41 PM
