Panasonic TC-P60ST30
  • jason123
    • Oct 2015
    • 1069
    I'd appreciate the help of someone with expertise on this TV. I downloaded the troubleshooting guide and I'm getting absolutely no power (No 5V Stby).. I'm actually not getting any activity on the TV at all (no blinking lights, no clicking, ...)
    On the troubleshooting guide, i see that my Power board is vastly different than the one shown. Does anyone have a troubleshooting guide for this specific TV? I'm concerned that when they say 5VSTBY is on P6 pin 6, that it's different on mine? No labels on the board (at least the visible side) to see what voltages are where.
    Assuming the guide is accurate, I have several power boards connected together. Which one would I replace? Any schematics out there?
    Thank you
  • jason123
    • Oct 2015
    • 1069
    Re: Panasonic TC-P60ST30
    Does anyone know what this lamp like G101 on the lower card supposed to be? Is this a gas discharge tube? should it be shorted or open?
    • R_J
      • 9547
      Yes thats a gas discharge tube and yes it will measure open. With power of measure the resistance of the 2 white ceramic resistors 3.9Ω and 3.3Ω.
      Do you get any relay click when you apply power? You should have STB+5V on P6 pin6
      with your meter on a/c volts place one probe on neutral and the other on F103, you should have 120v ac if not it's likely thos resistors R103 or R123 are open, probably R103 and if it is open I would replace S102 relay also
      • jason123
        • Oct 2015
        • 1069
        No, I get absolutely no life.
        • R_J
          • 9547
          I gave you a couple things to check, likely that resistor is open. You did check the fuses correct?
          • jason123
            • Oct 2015
            • 1069
            The fuses are all good. I will check resistors shortly. Thank you
            • jason123
              • Oct 2015
              • 1069
              R_J... Looks like R103 is reading 3.5 and R123 is reading 4.1 Ohm. No clicks / Relay activity
              • R_J
                • 9547
                maybe start by measuring the a/c coming into the lower board at P9, next at P55, center pin to ▲ if you have 120 vac up to there, check the small smd fuse F501 on the back of the power supply near P56
                You could also see if you have any DCV across C401 68uf/450v cap
                • jason123
                  • Oct 2015
                  • 1069
                  I have 120 all the way up to P56. 120 AC is also present on both sides of the large fuse. ~159 VDC across C401. Haven't checked the F501 yet.. I'm assuming I have to disconnect the board, so i'll wait for it to discharge first.
                  • R_J
                    • 9547
                    Do you have dc voltage across C362 1800uf/63v I believe the standby ic is under the silver heatsink next to [LIVE CIRCUT]
                    Also have a close look at the blue disc cap C404, check it for cracks or burn marks
                    It is likely the standby ic is bad.
                    • jason123
                      • Oct 2015
                      • 1069
                      No dc across c362.
                      C404 looks alright
                      • R_J
                        • 9547
                        What resistace do you get if you measure across pins 1 & 2 of the i401 ic and check the resistance of R414 it might be open, it supplies the B+ to the ic
                        You can check its resistance by checking between J33 jumper wire and any of the green resistors (using the lead next to the transformer)
                        • jason123
                          • Oct 2015
                          • 1069
                          0.1 ohm to full short.
                          So resistance from j33 and either side of the green resistors is high / open
                          • R_J
                            • 9547
                            What is 0.1Ω the ic pins 1 & 2 or the resistor? If that is for the resistor, thats good, if it's the ic thats bad.
                            • jason123
                              • Oct 2015
                              • 1069
                              I401 pin 1 to 2 is short. Resistance between j33 and green resistors leads is open
                              • R_J
                                • 9547
                                Thats why there is no standby, ic is shorted and opened fuse resistor.
                                • jason123
                                  • Oct 2015
                                  • 1069
                                  So i need to replace the ic and fused resistor? Is this doable or components are not available?
                                  And by the way, thank you so much for the help. Much appreciated
                                  • R_J
                                    • 9547
                                    The parts should be common, the resistor should have a value marked on it, the heatsink will need to be removed to id the ic, I don't know its number but it is likely common.
                                    • jason123
                                      • Oct 2015
                                      • 1069
                                      Thank you so much again R_J!
                                      • R_J
                                        • 9547
                                        no problem, post the number of that ic and resistor if you get a chance
                                          Acer Aspire A515-45G-R103 Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A515-45G-R103 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A515-45G-R103 boardview and A515-45G-R103 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-07-2024, 01:00 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • mostachio
                                          Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                          by mostachio
                                          Hi Badcaps,
                                          I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                          TV Details:
                                          Model # - TH-65DX700Z
                                          Symptoms:
                                          The television turns on and displays a picture then makes a clicking sound and turns off.
                                          I haven't opened it up yet but...
                                          09-04-2024, 02:32 AM
