Re: Toshiba 40L3433DG blinking red/green power indicator
On PSU board, Q301 is very hot?
Hello
As soon as I find 2 minutes I post photos of the old food and those of new side track.
When I start the Tv, voltage taken at the terminals of the connector that feeds the led strips, the voltage is 118 v which then decreases after a few seconds until 0 ...
I looked for a 5 V on the black connector that goes on the CM, and I did not find!
Is this name? no 5v just but 3 12V pin 10 11 12 ... There is a shunt that I can do to feed the back lignt and be sure that the leds are not in default and this so not to to open the slab?
Thanks for your help.
JeromeLeave a comment:
Hello again
After studying the tracks on the power supply card the 5v can not exist because no component are implants to generate it ... Q212 does not exist ... neither on the old power supply and on the new ... How so can I force the power card to charge to see the leds of the screen? I have to connect the pin No. 3 to what since I do not have a 5 V.
Hello
Can I see the good clear straight shot pictures of the WHOLE top side and bottom side of the boards (original and the replacement)?Leave a comment:
I saved all the photos on my computer, tried to trace the differences and find the correct schematic diagram for both PSU. But I had no luck, and am slowly going crazy over it.
So, you could do one more thing. Please flip the PSU, and make a few usable photos from the bottom side. I would like to see the connector area that goes to the mainboard. Maybe this way we can identify the standby part and begin to search for the solution.Leave a comment:
Good evening
The second card bought to replace the HS card was sold as fully functional, but I can not trust what the seller says. You want to take the transformer of the first card is Hs and I solder it instead of the one on the card on the tv and that does not work ... I hope that the transfo of the card is not is not defective and that it is he who would have roasted the transitor then that would also explode the circuits intergrés around the new transistor.
Would there be a difference between the 2 tranfos? that of the map of origin and that of the map mounted at the moment?
I still remember that when the card feeds to explode after a week, she also did not grill the motherboard
In any case thank you for all your patience
JeromeLast edited by Terrotiste; 10-08-2018, 02:28 PM.Leave a comment:
Hello
I put you two pictures. The first is the picture of the original power supply of the TV, and the second of the new card purchased on Ebay. You can see that the components around the transistor are different ... and that is the same reference of the power supply board. 069013R6
Thank you so much for your help
Ps: Bizarre if I start the TV with the ok key on the remote control pressed, the led on the front remains red. When I try to start the tv, the led will blink green / red . Some light noises in the power supply when the tv tries to startLeave a comment:
Hello
Ps: Bizarre if I start the TV with the ok key on the remote control pressed, the led on the front remains red. When I try to start the tv, the led will blink green / red . Some light noises in the power supply when the tv tries to startLast edited by Terrotiste; 10-06-2018, 04:01 AM.Leave a comment:
all the photos focused on the LIVE parts. its easy to follow and repair. first work on the new one. i faced before when i bought one on ebay. when it arrived was looking clean, but the PCB had surface crack so i worked on connect all the lines where effected by the crack.. check first for any crack.
the firmware 3rd file usb_auto_update_A1.txt you can find it over here i can call Tom66 wrote it years ago. but now the issue yours PWBLeave a comment:
Both power supplies are for 40 inch tvs, but there must be a reason why vestel marked them differently. So you should find the correct replacement for your power supply.Leave a comment:
Diah: the last time his power supply worked, his whole set was working. He shouldn't have eprom issues. At this point, we need to help him to make a working psu from a dead one and an incompatible one. For this we have to compare the 2 psu on component level.Leave a comment:
Good evening
The tv will not go to the trash right now .. Take your time Yonshee ....
Diah, thank you for your answer. I downloaded the compressed file but it only includes 2 bin files and images whose sizes seem very large ... no file mb90_en.bin or file usb_auto_update_A1.txt as usually found on the site Toshiba .. How should I use them?
I also said that when inserting the USB key on the TV, it does not seem to be read ... the LED of the usb stick is desperately off ...
thanks a lot for your help
Have a nice week end
the issue you have firmware corrupts . so the ST Flash from red to green
yours RC dont work because of the firmware corrupts . you need 3 files to put them on USB to start update..
thy this patched firmware for yours MB95 boards you need to log in then download itLeave a comment:
Oups it's the tv that will end in the trash if I can not find a solution ...
An idea please?
Thank you very much
No PLEASE do not put yourself in the trash...we need you..Leave a comment:
Good evening
Any idea to help me troubleshoot this damn tv? Or do I have to put myself in the trash?
Thank you very much .
Good evening
Find attached photos of the power supplies. The first 4 correspond to the original power adapter (old) and the last two to the current power supply on the TV s that does not work (new). You will see that the barcodes of the two cards are different. For the black connector it seems to be identical. The 2 cards are different because we see that in some places the components are different. Thank you for your help .
by mad_phillyHey all,
I have a Toshiba 49U6863DB with a blinking red/green power indicator, although it's intermittent. I went through https://www.badcaps.net/forum/showthread.php?t=45796 which is the same issue on another model.
There are no online updates per the settings menu and I cannot find any firmware for this model, only software from Vestel. I downloaded this and extracted to a blank FAT-formatted flash drive. Turned on the TV and inserted the drive. Media browser popped up and of course didn't recognise the files. Tried powering on with OK pressed but that didn't seem... -
by naddaw000Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...1 Photo -
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
by shahnldGood Day.
I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite... -
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
