Lg 43uh610v
  • tehmatix
    • Nov 2012
    • 174
    Lg 43uh610v
    This tv have a blue tint colour on the background. I dissasambled the panel and most part of leds have blue light. Only few leds in the middle of the panel has white colour. Is 3 rows with 8 leds each. The power supply for backlight is 77v/600mA. I checked and I had 76.5v , backlight 100 on settings.
    Could be power supply faulty, or I have to change the leds ?
    Thank you
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Lg 43uh610v
    I recently saw a post similar to this, with the blue/purple light background that turned out to be the backlights were purple. I would replace ALL the backlight strips to the normally used cool white type. You would have to verify if they a3V or 6V LEDs. I think however they may just be the usual 3V type. That will solve your problem before any circuits/component go bad.
    • R_J
      • 9588
      Re: Lg 43uh610v
      I remember that post... https://www.badcaps.net/forum/showth...ht=purple+leds
        • 12274
        • U.S.
        Re: Lg 43uh610v
        It is odd, from what I read, they can turn blue when they get old/worn out.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Re: Lg 43uh610v
          Originally posted by r_j
          +1
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Re: Lg 43uh610v
            Well at least you know the LED Driver is working and so to everything else on this TV. My recommendation would be to replace ALL the Backlight strips as suggested previously.
            • arenat
              • Nov 2015
              • 22
              • Argentina
              Re: Lg 43uh610v
              An overdrive led go blue .
              [/URL][/IMG]
              [/URL][/IMG]
              • tehmatix
                • Nov 2012
                • 174
                Re: Lg 43uh610v
                This backlight is with 1 + 2 row,1 bar with 8 leds in line = 24V, another's two bars 8x3+8x3=48v. I power up first bar with 24v from an external adjustable power supply and is the same thing like with board from tv.
                I order 3 bars from internet.
                • tehmatix
                  • Nov 2012
                  • 174
                  Re: Lg 43uh610v
                  I changed the all 3 strips LED and now is working. Thank you for attention
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Re: Lg 43uh610v
                    It looks as though this problem may now becoming more of an issue but well worth knowing the cause.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Re: Lg 43uh610v
                      Thanks for the feedback. We are happy you got your TV going again. Just remember to turn the Backlight setting to 65 on All the inputs and Modes. This will prevent a repeat failure in the future. Regards.
                      • We1shcake
                        • Feb 2019
                        • United Kingdom
                        Re: Lg 43uh610v
                        I've got the same problem, but can't seem to find where to buy the replacement LED strips, any advice?
                        • tehmatix
                          • Nov 2012
                          • 174
                          Re: Lg 43uh610v
                          Hi, I bought them from eBay
                          • andrews7523
                            • Apr 2015
                            • 117
                            • lancashire
                            Re: Lg 43uh610v
                            The problem is with the yellow coating on each LED cracking. If youremove the lense you will see that the yellow coating has failed therefore changing the colour of the LED from a white colour. This is happening to all LG Tvsincluding 43” 49” 55” and theworst thing is the LEDS aren’t available only full replacement strips
