Samsung UN55H6203AFXZA US01, open LED string…confirm my diagnosis?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    So yestirday I picked up a Samsung UN55H6203AFXZA with sound, no picture with an image on the screen for $40.00. It's a nice set. Backlights do not illuminate.
    Voltages are all present at indicated values except at the LED connector. I have volts at the first pair (callout “M1”) but no volts on the rest of them. Looking at the power board the LED's appear to be daisy chained together. Looks like the return volts must dump in to the next pair, then the next and so on.
    Pair voltages:
    “M1”.…… ramps to 325V, drops for about 7 seconds and ramps to 325V, repeat
    “M2” ……0
    “M3”…….0
    “M4” ……0
    “M5”…….0
    Voltage from “M1” positive to “M2” “M3” “M4” and “M5” negative are identical to the M1 pair, ramps 325, drops for 7sec, ramps 325 and repeat.
    My conclusion is M2 LED string is open.
    Would anyone mind confirming this for me? Thanks!
    They call me......."threadkiller"
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung UN55H6203AFXZA US01, open LED string…confirm my diagnosis?
    Thumbs up on that diagnosis. Yes indeed I do believe you have an open chain.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Thanks for the reply, I appreciate it!
      • angelos
        TCON and self diagnosis!
        by angelos
        Hi Guys.
        I have experienced something rather unique and need to find out by the forum what to make of it.
        I got in this set, a JVC or Telefunken LED TV whose complaint is that sometimes the set comes up blank with the back lights running. So I switched on and yes there was a blank screen and back lights were running. I checked the fuse on the TCON and sometime later I lifted the set off the table to check the image (the TV has no feet to let it stand upright) and noticed the set was cycling red, green blue, test pattern, blank then all over again doing this. Suddenly the no signal...
        09-19-2022, 03:05 AM
      • BMCappelletti
        iMac fan ramps up after shutting down. Software? SMC? FET?
        by BMCappelletti
        Hi everyone.
        There are some topics here (also on a lot of other places) regarding this issue, but I believe none has a definitive answer. At least I didn't see anyone saying it really worked for them.
        In my case I have an iMac A1418 (late 2012) that the fan goes full blast (or at least ramps up the speed) after going to sleep or turning the computer off.
        It's not a software issue, cause it was formatted and it happens with any MacOS version I test.
        At some places people say it would be an issue with the S5 rail. Others say it's the S0 rail. And some others say it's an SMC...
        01-17-2025, 08:11 AM
      • ADATA_C008/16GB
        10-character number and 4-characters string on USB Standard-A, "male" plug? Meaning and usage?
        by ADATA_C008/16GB
        I bought "ADATA C008 / 16GB" USB Flash Drive yesterday, and I'm curious about meaning and usage of this 10-characters number and 4-charatcer string on USB Standard-A, "male" plug.
        11-10-2024, 11:47 AM
      • travisbklein
        Sony STR-V25 Receiver - Tuner String Came Off
        by travisbklein
        Hey guys what's up, looking for maybe some guidance on how I can get my tuner string back on and taut like it is supposed to be.
        I took a few photos that I will show at the bottom and I tried my best to illustrate the problem.
        1st problem is that the string seems to slip on the metal tuner rod instead of catching and staying tight. I saw a video where a guy had the same problem and he just use a nail file to scrape up the small rod to allow it have some friction with the string and hence allowing it grab it and not slip.
        2nd problem is I'm not...
        12-18-2018, 12:02 PM
      • backdoorsecurity
        p51 uefi chip diagnosis
        by backdoorsecurity
        hey all i was messing around with digmorepakas thinkpad firmware advanced menu patches without success "resulted in black screen". i could flash modded file then flash the backup if needed. it got late so i put the p51 away and forgot about it for a month. i recently pulled it back out, flashed the backup file and it blackscreened. "screen turns on no splash". i had originally made 3 backups and diffed them, file integrity was good. i downloaded the files i could find on this site and it boots to splash then boots os but takes about 5-7 minutes to reach splash. i am trying...
        07-20-2025, 08:27 PM
