SAMSUNG LA32C350D1 No Sound on HDMI
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Hi guys,
    I have an old Samsung LA32C350D1 Lcd that has sound viewing RF reception, but no sound when viewing HDMI.
    I have had other model Samsungs with the same problem, but they just required going to the 'anynet' settings in the menu. (I cant remember the actual change I made). However this set doesnt have the 'anynet' settings in the menu.
    So I'm guessing this is not just a setting, but a fault. Could somebody please help. I've have included a photo of the main board
  • CapLeaker
    Leaking Member
    • 8210
    Re: SAMSUNG LA32C350D1 No Sound on HDMI
    Did you try a factory reset?
    • Grunder
      • Jan 2016
      • 323
      • south africa
      Hi Capleaker, yes, sorry I should have said so. I also tried shorting pins 5 & 6 on the two eeproms I could see hoping for a wipe of the eeprom but no joy. (this technique has never shown results for me?). In the meantime the local agents list the main board as no longer available.
      • CapLeaker
        Leaking Member
        • 8210
        Did you try a known to be good HDMI cable and maybe a different HDMI source you know that works?
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Yes, the blue ray player with hdmi output was used on other sets in workshop, and worked fine.
          • CapLeaker
            Leaking Member
            • 8210
            That just about leaves only the software or the main ic.
            • Grunder
              • Jan 2016
              • 323
              • south africa
              Yes, not what I was hoping for. Had hoped for a fix via the factory settings.
              I don't have an eeprom programmer, and am doubtful of sending the set to the local agents. They would just quote for a new board, which is most probably no longer available locally.
              The TV is in a shitty condition, and the owner indicated not wanting to spend too much on the repair. It's an oldish Lcd and wonder if the effort would be worth it? Bit of a defeatist attitude, but don't want it coming back months later with other issue's. So to play it safe, and possibly save the customer some money in the long run, I'm just going to return it not repaired. Thanks the input.
              OH Lastly, what is the difference between memory on a usb stick, and memory which either comes preloaded on the eeprom, or that which gets down loaded & written to the eeprom?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4362
                • Italy - Milan
                But the factory reset was made in service menu or user one?
                  Samsung N 10-anyNet Netbook Specification for Upgrade or Repair
                  This specification for the Samsung N 10-anyNet Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 10-anyNet boardview and 10-anyNet schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Samsung...
                  09-06-2024, 05:27 AM
                • jchang
                  Samsung UN70NU6900F no picture and no sound
                  by jchang
                  Hi all
                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                  Symptom:
                  No picture no sound.
                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                  No sound at all.
                  What I tried:
                  1. I tried unplugging the left or right ribbon...
                  01-09-2023, 06:28 PM
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • japlytic
                  Not all TVs can handle surround sound on a HDMI input
                  by japlytic
                  With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
                  So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
                  08-31-2022, 10:09 PM
                  09-06-2024, 06:20 PM
