Philips 32PFL3008H/12 bad backlight
  • d4vidb
    • May 2018
    • Slovenia
    Hello, I'm repairing Philips TV which has Vestel 17IPS19-5p power supply. So far I replaced 400V MOSFET, diodes and MP3394 and TV started to work again but with very low brightness and I only see the picture in the dark room.
    Voltage across the LED is around 50V which is not enough I guess?
    What should I check? Capacitors are OK, so I don't know what else to check.
  • ngth82
    • Jul 2015
    • 541
    Re: Philips 32PFL3008H/12 bad backlight
    Please post clear pics of the boards.
    What happens if you test the backlights with a backlight tester?
    What is the voltage output of the LED driver pins?
    I ask because i've seen LED strips that appear much dimmer compared to the strip next to it. Some of the LEDs have probably gone bad and requires a lot more current to get them to full brightness. Time to replace the LEDs or get a new panel strip.
    -Thomas
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
    • snowfun
      • Aug 2012
      • 21
      • Portugal
      hi,
      I have a silimar case and my fault was ic driver MP3394, the voltage was low and image very dark.
      You need make a test with the led bars first 50v is low (for example: in 32" tv backlight have 2 bars with 11 leds , well 11x3v =33 x2 = 66v
      Regards.
      • chestercc
        Philips TV Backlight Repair
        by chestercc
        So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
        My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
        The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
        11-18-2022, 01:15 PM
      • ohren
        Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
        by ohren
        I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
        The setup is basically:
        Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
        Transistor is switching the 3.5 V supply on the power board....
        12-05-2024, 11:10 AM
      • Patrick501
        Philips 55PUS6704 no picture, backlight ok
        by Patrick501
        I'd like to repair a Philips 55PUS6704.
        It turns on and you can see the backlight, hear the sound but no picture.
        When I disconnect one of the T-con cables, half of the screen turns white.
        right cable disconnected= right side white
        left cable disconnected= left side white
        When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
        There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
        Also you can notice one single...
        11-12-2025, 08:46 AM
      • ovrax
        Philips 55PUS6804/12 turn on & off (probably backlight issue)
        by ovrax
        First of all, please excuse me as I'm quite new to this field.
        I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
        I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
        The Ambilight works perfectly and stays on.
        No sounds.
        Thanks in advance.
        08-25-2024, 04:33 AM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
