Need the flash for Vizio VO370M for U18 board # 3637-0512-0150
Vizio EEPROM dump needed
VIZIO VO370M Flash dump
VIZIO VO370M
Main board:3637-0502-0150(0G)
Panel LC370WU
FLASH:MX25L3205DAttached Filesif you find these attachements useful please consider making a small donation to the site
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by erkko13Ho ho ho, badcaps people,
if this qualifies as bios request, hopefully. Actually BIOS2 for that laptop is second smaller SPI flash (Winbond W25Q80DVSNIG-GP-U), containing supposedly some config for TPS65988 which in turn manages USB-C stuff, including PD. This is possibly flash, where update "Power Delivery Firmware (TI TPS65988)" F407.06.29 -- https://download.lenovo.com/pccbbs/mobiles/r10pd10w.exe does its thing. Previous owner claims that after clean install of Windows 10 he installed thinkvantage tool of sort, which updated everything for that laptop. I did glance over...-
Channel: BIOS Requests ONLY!
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by edgarmg15Hi everyone
I´m trying to repair a TV Vizio E320-A0 that I found in the street
The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)... - Loading...
