ves400unes-03-b chassis No picture, sound ok
  • freccia
    • Mar 2012
    • 26
    • Malta
    So. I have this 40 inch led tv called Gala with the chassis ves400unes-03-b from Vestel. Closest one to it is a Hitachi 42HXT16U. It has a GA 60hz FHD Vo.3 Sticker Part No P26098d TCON Board.
    Now I have measured the input voltages and they are ok.
    With the other two ribbon cables connected to the panel, the voltages on the output of the t-con drop to less than 1volt.
    When I remove the right ribbon cable and leave the left ribbon cable connected, the picture comes up on half the screen and white with some black thin lines on the other side.
    When I connect the right ribbon cable on the t-con and remove the left ribbon cable on the output of the T-con, all the voltages go down on the output of the t-con.
    Now I have a difficulty determining whether it is the T-con which is at fault or the panel, although I thing it is more that the tcon is faulty.
    Can anyone help me determine which one is at fault please?
    Also if it is the T-con, how can I make sure that I am ordering the correct part please?
    Thanks for your help.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: ves400unes-03-b chassis No picture, sound ok
    Post pictures of your Tcon to start off.
    • freccia
      • Mar 2012
      • 26
      • Malta
      Ok I am going to post some pictures which might help show the issue. Below you will find the pictures of the t-con board and the symptoms with the two cables (blank screen only backlight), with one cable on the left (image on the left is good and white with lines on the right). If you need more information please do not hesitate to contact me. Thanks.
      Photo 1
      Photo 2
      Photo 3
      Photo 4
      Photo 5
      Photo 6
      Photo 7
      Photo 8
      • freccia
        • Mar 2012
        • 26
        • Malta
        Photos 1 and 2 are of the T-con with all the cables connected. Only the backlight will show as on photo 4.
        Photo 3 is the main board.
        Photo 5 is a photo of the t-con without the right ribbon cable and produces a picture like the photos 6 and 8
        Photo 7 is the picture from where the ribbon cable on the t-con is removed.
        Thanks and hope that you find them useful in helping me resolve my issue.
        If you need more info, please do not hesitate to contact me. Thanks
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          It does look like a panel fault. When one ribbon is removed and you have a good picture on half of the panel but does not repeat when you replace that ribbon and remove the other ribbon.
          When the ribbon that does not produce the half picture is connected, is that when your voltages on the Tcon start to drop.
          There is a possibility that a ceramic capacitor on the small panel board that the ribbon connector connects to (which is joined to the panel) may be short circuit.
          • freccia
            • Mar 2012
            • 26
            • Malta
            Yes when I connect only the other ribbon cable, the voltages onthe output of the tcon go down, like it shuts down. What about those black lines on the other half when the screen shows half ok?
            Do you think the small ceramics on the panel pcb could be shorted? I will check them just in case
            • freccia
              • Mar 2012
              • 26
              • Malta
              Yes you were right. I am finding a short on all the capacitors on the thin long pcb which connects the ribbon cables of the panel to it. Found 6ohms on some and 4 ohms on others. That is why when I connect the right ribbon cable on the tcon it shorts the supplies. There is one HAVDD which is shorted for sure. Mind you this board only has resistors and capacitors on it, no semiconductors, at least I cannot see any.
              Excuse my knowledge, but is there a way to check the shorted capacitors on the board without having to remove them one by one please?
              Thanks once again for all your help.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Unfortunately not that I am aware of. Others have been successful taking them off one at a time until they found the short circuit. I would lift one off, test it and then put it back if it is not shorted.
                That way you won't lose the position or mix them up.
                • freccia
                  • Mar 2012
                  • 26
                  • Malta
                  Ok thanks for your reply. I will have to remove them one by one then and check each until I find the culprit. I hope it is not the display which is causing these shorts but those capacitors. Will see what I can do, if I find the faulty one I will let you know for sure. You saved me from buying a tcon for nothing. Thank you very much sir for your help.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Good luck
                    • freccia
                      • Mar 2012
                      • 26
                      • Malta
                      Hi. I found the problem with this led tv. It wasnt the capacitors, but a ribbon cable going to the panel, and it has a driver chip on it which was shorting to chassis and is burnt. I wonder if I can find a ribbon cable for it and how I can fix the cable to the panel. Anyway at least I found the faulty component and learnt a lot from it. It is working except for those 15cm approx black screen where that ribbon cable is connected to. Thanks very much for your support Dick Burton.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Unfortunately this is not repairable without extremely expensive equipment https://www.youtube.com/watch?v=tMiLuiDSnQ4
                        • freccia
                          • Mar 2012
                          • 26
                          • Malta
                          Also you need to find from where you can get this special ribbon cable. I cannot find anywhere where I can get hold of it since it has a driver embedded on it in the middle.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Yes. That is the TAB/COF IC Part No. you would have to look for. It would be along one of the edges. and to repair/replace that then you would need special TAB Bonding machinery and equipment to do that operation.
                            • freccia
                              • Mar 2012
                              • 26
                              • Malta
                              Hi Andrew. From where do you think I can get the part number please, cos I think that it is worth a try with a lot of patience(TV is mine, not of a client). is it related to the panel size and panel manufacturer? Thanks
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                freccia, I believe that there is no cost effective way to replace the COF chip at this time.
                                • Tr0ll
                                  by Tr0ll
                                  Original T-con:
                                  First replacement T-con:
                                  10-07-2023, 07:48 PM
                                • LEECH666
                                  Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                  by LEECH666
                                  Good day ladies and gentleman!
                                  I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                  This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                  I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                  01-19-2024, 05:46 PM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
                                • ChaosLegionnaire
                                  by ChaosLegionnaire
                                  09-13-2022, 09:02 AM
                                • PNI E.
                                  tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                  by PNI E.
                                  hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                  02-20-2025, 08:36 AM
