Samsung UH50EH5300FXZA, help with a transformer?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    #41
    Re: Samsung UH50EH5300FXZA, help with a transformer?
    Originally posted by R_J
    I made a change in my post, I ment QM808
    To check this transistor, use diode test, with one probe on the base, check the collector then emitter, should read around .6xx, then reverse the leads and should read close to open. Then check between collector and emitter, this should read open both ways (depending on other in circuit components)
    QM808 checks good.
    EDIT/ADD: Is there a way to fire up the board out of the TV for actual voltage testing? I see several places on the back of the board that look like test points. Maybe if I test for voltage that way we will find the culprit?
    They call me......."threadkiller"
      So what DC V do you you have on each pin of the Transistor? GND ref will be the negative leg of the main filter cap.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        #43
        QM808 voltages main cap ground referenced:
        Emitter: Started at 1.1v and slowly fell off to .79v
        Base: 4.1v to 4.15v with an occasional rise to 5.3v
        Collector: 3.92v to 4.2v with an occasional rise up to 5.2v
        Voltage at A5V is now gone
        • R_J
          • 9625
          You can run the board out of the tv without a problem. Like I said before, the board will try to turn all the supplies on unless you ground the PS_ON pin.
          So ground PS_ON again and see if you have A5V
          This power board has 3 seperate power supplies. The standby/run supply for the A5V. It also supplies the B5V and B12V when turned on.
          Then there is the PFC power supply. and the LED driver power supply
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            #45
            Ok I will pull the board and re-test with it out. First will be to verify whether or not A5V exist at its pin with PS_on grounded.
            After that, one of your concerns was whether or not VCC was present on PIN8 of the LED controller IC. Should I check that next, and then measure test points for voltage in the areas of suspicion? I will record these with the hope it will help troubleshooting.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              #46
              A5V is a steady 5.2v with PS_on grounded, chassis ground reference
              You are correct R_J, VCC is missing on pin 8 of the LED controller IC.
              Questions:
              Pin 1 of the LED controller IC has 89 volts on it, reference earth ground
              All pins of LP802CS have 166v. This is "sparkly joe", or the "transformer" I referenced in the original post.
              There's no way these voltages could be correct, right?
              • R_J
                • 9625
                LP802CS is a COIL it is NOT a transformer. It is one single piece of wire, It comes direct from the bridge rectifier so 160 volts is correct, on all leads.
                The ic I was refering to was ICP801S, It is the PFC circuit, this is the circuit that boosts the voltage coming from the bridge rectifier from 160 volts to 400 volts on the main filter cap CP806S
                The LED controler/driver ic is the ic near the led plug.
                  Please check the resistance between point A and point B for me to see if it shows < 1 Ohm.
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    #49
                    Thanks R_J. I think budm is referring to this in his last post too.
                    Resistance is not less than 1 ohm. It is 22.5ohms. I'm guesing we just checked that leg of the IC for short?
                      No, I am looking for the switched Transistor that supplies the Voltage to VCC pin 8 of the PFC IC, I could not see QM808 that RJ is referring to.
                      • R_J
                        • 9625
                        Check the JRM803 0Ω resistor next to point B. QM808 is the transistor at point B, it is marked on the other side of the board
                        I am guessing DM809 diode and CM809 cap. are the supply for the that transistor?
                        QM807 is likely another switch.
                          Hi Rj, so that is QM808 then, I was tracing the bottom side of the board to find out how that Transistor is connected to pin 8 of the PFC IC.
                          I also expect one of the leg will show 15 ~ 20 vdc when PS-ON pin is grounded.
                            it looks like CP812 is the filter cap for the PFC IC pin 8.
                            I also wonder if these Lytics caps are OK: CM809, CM814, and that CP812.
                            I also cannot clearly see the RP824 value, it has one end connected to the + leg of cap CP812, the + leg of the CP812 should also show <1 Ohm to point B the leg of QM808.
                            BTW QM808 P/N? Is it NPN?
                            • DXseekerMO
                              • Feb 2018
                              • 1119
                              • US
                              #54
                              JRM803 is straight through, zero resistance.
                              • DXseekerMO
                                • Feb 2018
                                • 1119
                                • US
                                #55
                                RP824 is marked 022, there is also a line above the 2, thinking this is 220? I have not checked CP812 for capacitance but can do.
                                QM808 is MPS751Y, datasheet says it is PNP
                                Positive leg of CP812 to point B as marked on the previous picture is .4ohms. From the + of CP812 to leg 8 of the PFC IC is 22.5ohms
                                Originally posted by DXseekerMO
                                Caps CM809 and CM814 have proper capacitance out of circuit.
                                • R_J
                                  • 9625
                                  If you look at the schematic of the BN44-00520C, there is a 22Ω between the transistor switch and the pfc ic vcc, which would make sense.
                                  • DXseekerMO
                                    • Feb 2018
                                    • 1119
                                    • US
                                    #57
                                    On RP824 there is 022 with a line on top. Does this line denote "this side up" to read the value properly?
                                      When PS-ON pin is grounded, I do expect at least 12V on the Emitter pin of the QM808 (PNP, It is turned off when PS-ON is grounded).
                                      • DXseekerMO
                                        • Feb 2018
                                        • 1119
                                        • US
                                        #59
                                        Redacted.
                                        Redacted again
                                        So what supplies voltage to pin8 of ICP801S with PS_on grounded? Is there supposed to be voltage there with PS_on grounded or were we just checking for a good pathway with the resistance test?
                                          The Voltage on the Emitter is generated by the AUX winding of the transformer which is fed to the switched Transistor QM808 Emitter (because it is PNP transistor), there will be no output on the Collector until PS-ON is present. The PFC IC running Voltage is around 12V.
                                            09-07-2024, 05:50 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
