vestel 17pw07
  • cossiejay
    • Nov 2010
    • 83
    vestel 17pw07
    looking for some advice please got a tv with this board in it the main fuse had blown replaced it but blow again straight away any ideas please the tv is a hitachi 40h6l03 uk spec 230 v thank you
  • R_J
    • Jun 2012
    • 9624
    Re: vestel 17pw07
    You really have'nt given much information, A picture of the power supply would help. Likely there is a component in the primary that is shorted, like a mosfet. Q201 Q202?
    • cossiejay
      • Nov 2010
      • 83
      Re: vestel 17pw07
      ok thank you could i just buy another from ebay or has it to be excatly the same
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        08-18-2025, 11:38 AM
      • massimomax
        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
        by massimomax
        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
        spero che qualcuno può averlo per riprogrammare eprom. grazie
        Post in English !!!
        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
        02-28-2025, 07:27 AM
      • Bazilwrc164
        Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
        by Bazilwrc164
        I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
        The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
        I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
        If anyone can provide:
        • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
        • Or a compatible EEPROM dump
        07-23-2025, 12:15 PM
      • Askic
        Hitachi (Vestel) TV is not turning on
        by Askic
        Hello guys,
        I have 32 inch Hitachi TV with Vestel PSU board 17IPS71. Tv was working normally and I shut it down normally via remote control.
        The next morning it couldn't turn ON neither with remote controller or via button on the logic board.
        There is a red standby LED ON, so it is not dead totally.
        I have examined the PSU board and I cannot find find any traces of blown components or bulged caps. Electrolytic caps are manufactured by Elite.
        I also check diodes and big MOSFET (with cooler/heatsink). It seems OK.
        Can you tell me based on...
        01-11-2023, 12:34 PM
      • EnricoS92
        Hitachi 43HAE4251 - Vestel 17MB171 - Displays logo and reboots
        by EnricoS92
        I have a problem with this tv Hitachi with vestel 17MB171 board.
        I turned off a couple days ago and the next morning when I turned on it had the issue, i tried to left the power unplugged for several hours but nothing.
        The tv turns on shows the logo picture and after a few seconds reboots, and start over again.
        I was able to connect via uart to the tv and grab the log I attached, it has logged 3 reboots.
        I believe it is a corrupted software, but I could not find any online, does anyone has it, or where to download....
        12-08-2021, 05:59 AM
