TX-P50VT20E 10 Blink Code
  • rgarcihm8
    • Apr 2018
    • Spain
    Hello, i'm getting this 10 Blink Code on my Panasonic TX-P50VT20E, all i have done is this:
    1-. Troubleshoot 10 blinks failure. https://imgur.com/a/wS3DR
    This Troubleshoot said me SC board is defective.
    2-. I've done su/sd resistance test without errors. https://imgur.com/a/juQEX
    i'm not technician, only user and want to know if i can do more tests to sure is the SC board.
    Thanks a lot, regards from spain.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: TX-P50VT20E 10 Blink Code
    Have you checked all the solder joints to make certain they are all good especially around any coils or where there are rivets. Also are all the securing screws in nice and tight.
    What voltages do you have or are missing?
    • rgarcihm8
      • Apr 2018
      • Spain
      All solder joints good, securing screws too.
      voltages i have or missing don't know what you mean, i test some voltages on the PBoard that i read on service manuals, but nothing special.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The back panel should have a label on it giving various voltages which should match the test points on the circuit boards. Also the circuit boards may well show other supply voltage test point. Without pictures of your boards it's all guesswork at to what they should be.
        • tn245
          • Oct 2013
          • 530
          Most likely SC board multiple components shorted. If you disconnect the SC board and switch on the blink code should change to 7. Also check Q661 on SC board - most likely shorted.
          Here's the monster TNPA5081 rebuild thread:
          https://www.badcaps.net/forum/showthread.php?t=26322
          • ramiz
            • Mar 2018
            • belgrade
            Hello everyone, I need help, I have panasonic tx-p50vt20e problem is tnpa 5081, I got a picture but I'm losing it, after some time I buy another TV the same model, and order y plate is correct, I install it in the TV but I only get half the image, in the upper part has a picture but in the lower no picture, I place the same board in another TV that is the same model, I get the same picture, but I got the picture on the other board but the picture was poor, but it was whole, is it possible that the nand upiso error on the processor board, and that's why I do not have the whole picture on a single TV set, please, for help
            • sordids999
              • May 2013
              • 2171
              • uk
              Hi guys
              Does anyone know where I can get a diode for this tv it's a T3D04 preferably in the UK if possible
              • sordids999
                • May 2013
                • 2171
                • uk
                Tv runs fine for 5 minutes then switches off and 10 red led blinks
                Checked for cold solder joints on psu etc
                Bit lost what to check now
                • cloo
                  Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                  by cloo
                  I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                  It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                  So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                  After doing a factory reset this problem was gone and the picture was back to...
                  01-06-2025, 06:02 AM
                • rmacintosh
                  Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                  by rmacintosh
                  I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                  The symptoms of the tv ar as follows:
                  • Plug AC in to back of TV
                  • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                  • The 3 blink code is given by the power LED
                  • If the TV is unplugged and then
                  03-14-2020, 12:24 AM
                • Boardview and Schematic Bot
                  LCD LED TV Service Menu Codes
                  TCL LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  10-31-2024, 03:58 AM
                • reporter1979
                  2 red blink code on old led tv Sony KDL-40W2000
                  by reporter1979
                  Hi all, the TV KDL-40W2000 was flashed by a lightning.
                  Firstly I got the 3 red blink code.
                  Following other threads I changed the power supply board and got always 3 blinks.
                  So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                  The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                  What else can I do?...
                  02-17-2023, 11:50 AM
                • Curtissimo
                  HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                  by Curtissimo
                  Hi everyone.
                  I have a HP Elitebook 850 G8.
                  Serial: 5CG2324XM0
                  ProdID 6L8D5EC#ABA
                  It has a Winbond W25Q256JVEN Chip.
                  I need to remove BIOS Password.
                  I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                  Attached my dump.
                  I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                  I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                  What I did:...
                  08-26-2025, 04:42 AM
