Samsung lcd tv no power
  • taft1957
    • Oct 2013
    • 95
    Re: Samsung lcd tv no power
    Originally posted by budm
    I would not using Beep function for testing for shorted circuit since the meter will beep with resistance as high as 50 Ohms or more depends on your meter, you can try checking with various resistor value to find out at what the resistance the meter will stop beeping.
    Beeping function will tell you that you have electrical connection between point 'A' and point 'B'. Resistance result is the one you need to look for.
    You should use low Ohm mode for looking for shorted circuit (something thing that has <1 or 2 Ohms reading). Ohm reading is the way to go for looking to see if you have shorted circuit/shorted parts or not.
    OK with the meter on ohms mode, on that left pad of transistor I get 219 ohms ON the capacitor, 0.1 ohm on negative side 0.833 k ohms on positive side.
    • taft1957
      • Oct 2013
      • 95
      Originally posted by ngth82
      It would help if you are able to mark up the photos in MSPaint or some other photo editor to clearly indicate which paragraph aligns with which pic.
      In any case, the beep function isn't what you want to use. Budm mentioned the same thing. Use the low ohm measurement function of your meter to measure the resistance.
      For the zoomed in picture (attached), the right hand side appears to be GND. Look at the copper pour (shape) on the board. By inspection, the majority of the 0402 and 0603 sized caps that you have here share the same net.
      Since you say the the left hand side is also measuring low impedance to GND, it indicates the left hand net is shorted, but not necessarily across this cap.
      What RESISTANCE value are you getting across this capacitor?
      OK with meter in ohm mode. I get 219 ohms on the left pad of transistor. On that capacitor, positive side I get .833 k ohms.
        We need all 3 pads resistance readings:
        pin1 (left pin)
        Pin 2 big pad
        pin3 (right pin)
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
