LG 42PW451ZD - Z-SUS Zener Diode 2 Missing
  • Salvatore057
    • Apr 2018
    • 12
    • France
    Hello everybody,
    I am new to this forum or at least a new member because I used to read a lot of useful informations since several months.
    I am trying to repair on of my TV which the relay is clicking while I try to turn in on.
    Thanks to the useful advices I have located the issue on the Z-SUS board and maybe on the Y-SUS on as well (I need to check it later).
    The issues I have found on the Z-SUS board were two shorted IGBT 30F124 that I will replace with two 30J124 and also change the IC7 and IC8 on the board. I also noticed a short Zener Diode noted ZD2 attached to one of the 30F124 IGBT.
    I have removed this diode but I cannot identify which replacement part I should use.
    Could someone help me?
    I have read somewhere that using a 20V SOD323 diode should be ok.
    Thanks a million for your help.
  • buchman
    • Aug 2015
    • 294
    • greece
    Re: LG 42PW451ZD - Z-SUS Zener Diode 2 Missing
    I have the same problem, how did you test the zener diode and the ic's?
    I have replaced 2 IGBT's and it didn't help.
    • Salvatore057
      • Apr 2018
      • 12
      • France
      In order to test the zener diode I removed the 30F124 that was linked to it and then I check for continuity.
      Regarding the IC, I did not check it and I am not sure that there is an easy way to check it. But it is recommended to replace the driver IC when replacing an IGBT. If you do not do that, I think that there is a high chance that you will have to replace again the IGBT.
      When you say that you replaced both IGBTs and it did not help, is your TV still clicking? Have you only connected the ZSUS w/o the YSUS board?
      • buchman
        • Aug 2015
        • 294
        • greece
        after I replaced a few IGBT's on the ysus, the tv stopped clicking and even the voltages are fine now. But, if every thing is connected then 2 IGBT's on the ysus are still blowing up UNLESS I disconnect the ribbon cable between the zsus and the t-con board.
        • Salvatore057
          • Apr 2018
          • 12
          • France
          Are the IGBTs that are getting damaged on the Y-sus the two IRG7IC28U?
          Have you replaced the IC drivers? Maybe, they are getting damaged because the IC drivers are bad.
          Have you checked solder on the two big coils?
          • buchman
            • Aug 2015
            • 294
            • greece
            I replaced the IRG7IC28U with 30J124 and yes, they are the two that are getting damaged.
            I didn't replace the ic drivers.
            checked the soldering and it is fine.
            • Salvatore057
              • Apr 2018
              • 12
              • France
              Did you finally solve your problem?
              I received some parts to fix my TV today but not yet the missing zener diode.
              I took a chance in replacing the 30F124 on the ZSUS with some 30J124 leaving the space empty where the zener diode should be (because I think that they have a protection diode inside).
              I replaced the YSUS shorted IGBT as well.
              I first tested the ZSUS w/o plugging the YSUS and the TV turned ON without picture but I had some sound and the voltages were fine. I then plugged the YSUS to the ZSUS and the TV started to click again without turning ON.
              I checked the YSUS and no IGBT were short but the ZSUS is again damaged. I think I will wait until I get the zener diode and I will then also replace the FAN73711 IC drivers.
              Hopefully it is not the YSUS than is damaging the ZSUS.
              • Salvatore057
                • Apr 2018
                • 12
                • France
                I did another test to check if the YSUS board was responsible for the ZSUS being damaged.
                I removed the shorted IGBTs from the ZSUS and plugged the ZSUS back in the TV with the YSUS... and then miracle I had a picture on the screen.
                So the YSUS seems to be ok.
                I have now replaced the FAN73711 from the ZSUS and also replaced the IGBTs. I will wait today to see if I get the diode I ordered. If not I will try to mount a larger Schottky diode just to do a test (SS14).
                • buchman
                  • Aug 2015
                  • 294
                  • greece
                  I am still waiting for my parts. Please let me know if you fixed it and how.
                  Thanks.
                  • Salvatore057
                    • Apr 2018
                    • 12
                    • France
                    Here are some updates on my issue.
                    I finally managed to get a picture on my TV with both ZSUS and YSUS plugged but the picture is blurred and purple (see pictures attached).
                    What I did is to replace Q708, Q709, Q703,Q713 and the IC702 on the YSUS and install the 20V Schottky diode that was missing on the ZSUS.
                    Do someone know why the picture looks like that?
                    Is it the ZSUS that is still faulty like described by tom66 in his troubleshooting guide?
                    https://www.badcaps.net/forum/showpo...39&postcount=2
                    • Salvatore057
                      • Apr 2018
                      • 12
                      • France
                      My problem is now solved, I replaced the ZSUS board and the colours are back to normal.
                      I ordered more parts and will still try to fix my old ZSUS board.
                      Cheers
                      • fontypsix
                        • Jan 2020
                        • Russian Federation
                        Cheers
                        Hi, I have the same problem now. Did you fix your old ZSUS? There are no such expensive parts and I'll try to solve it too.
                        • chuckjuggernaut
                          • Sep 2023
                          • 10
                          Hi Ian looking too for the same board…. I need a Part, I think diodes. D23 and D23. Has anybody schematics for it?
                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                            by sam_sam_sam
                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                            I bought this from an eBay seller but unfortunately they only had one
                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                            I bought three of from them to also make battery packs with this output power limit in mind
                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                            04-23-2025, 05:50 AM
                          • nev1001
                            What zener diode might fix the sound on Maestro Mayhem gaming chair?
                            by nev1001
                            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                            I think an issue could be a zener diode (or capacitor) which has shorted out.
                            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                            04-17-2025, 05:09 PM
                          • Vincenzo2
                            Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                            by Vincenzo2
                            My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                            Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                            I put some pictures here to show that it is labeled "M7"....
                            09-07-2023, 07:43 PM
                          • hobostove
                            Corsair RM1000e - Help identify 5VSB Zener diode
                            by hobostove
                            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                            There's a 22ohm resistor that's melted and open, but it still has the bands.
                            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                            It looks like the diode connects the source and drain of a TNY284...
                            03-27-2025, 02:25 PM
                          • Dvsr
                            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                            by Dvsr
                            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                            After replacing the caps I started testing out the speaker. It seemed...
                            09-10-2025, 10:20 AM
