LG LED 42LW5500-ZE powers on, but no picture or sound
  • Trofazni
    • Dec 2016
    • 71
    • Serbia
    Re: LG LED 42LW5500-ZE powers on, but no picture or sound
    Originally posted by Andrew F. Ali
    +10...Yes it is true. A lot of LGs have a BGA issue and reflowing with a hot air station at 350C for ten (10) minutes worked for me on many LGs recently, especially those LW series. Keep the hot air steady on the BGA chip. Of course remove the heatsink and tape from off the IC. Before reinstalling verify none of the components under the chip has been moved or shifted.
    Yes, I can confirm this, the problem was in main bga chip, I took it off the board, 1/3 of the pads on cpu were different colour, without balls on them, like cpu had heating issues. Put the new balls, resolderd it, works fine for two days allready... Tried with hotair and flux, didn't do anything.. Replaced balls after taking off cpu and reinstaling it on an ic rework station, and it works... I assume hot air didnt do anything because of condition of pads on cpu. I will call this succesful, and i would like to thank you for pointing me to solution
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Good to hear you were successful. Thanks for the follow-up.
      • francis_!970
        • Jun 2022
        Thanks for this!
        So I repaired my LW5569S now.
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
