vestel strips
  • Newbie123
    • Oct 2015
    • 58
    • uk
    vestel strips
    Hi all stupid question time can you replace the vestel strips that are marked ves400unds,40 ndv revision 1.0 with the ones that are ves400unds,40 ndv revision 0.2?,is there any difference between the two revisions?,the screen panel is ves400unds-02,im a newbie so please be gentle..,the strips look identical to the eye except the revision difference..many thanks in advance!
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: vestel strips
    as long as there are the same amount of leds on each strip i personally cant see a issue with using them i would certainly take the risk myself
    • Newbie123
      • Oct 2015
      • 58
      • uk
      Re: vestel strips
      Thanks for the reply Vince,much appreciated,Happy Easter to you as well.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Re: vestel strips
        +10
        • Jaime Morillo
          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
          by Jaime Morillo
          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
          The TV was stuck on the logo and I couldn't access the update menu.
          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
          The image result was good, but the image is inverted.
          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
          08-18-2025, 11:38 AM
        • France_53
          Vestel tv, how to flip the image?
          by France_53
          Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
          05-12-2024, 05:22 AM
        • edugimeno
          Help findinf LED strips for TDSystems K32DLT1H
          by edugimeno
          Hi There!
          I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
          Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
          Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the...
          11-05-2022, 03:36 PM
        • eccerr0r
          What to do with bad LED strips?
          by eccerr0r
          I suspect a lot of you have done a lot of repairs and end up with a lot of bad LED strips...what do you do with them?
          Wonder if I should get a pile of LED chips and try to replace the bad units for the heck of it, but I don't really need the strips at the moment because I bought the strips...
          Oh... and I think I got my TV working again, though not 100% I don't think, on a white screen I can see a bit of the ghost of the LED strips, must have done something wrong or the LED strips aren't quite the same as the original...
          10-22-2022, 12:27 AM
        • h4rdw4re
          Grundig 40VLE7131BF led strips doesn't light up
          by h4rdw4re
          Hi guys,
          I have one very old TV.
          Main problem I have with this tv is that led strips won't light.
          I measured voltage levels, and inverter input is 24V.
          other voltages are also ok.
          What I found is that removing and connecting again connector CN1 led strips lights for shorts time (but only once). When led strips lights up then light is uniformly spread on whole panel.
          First I thought that led strips are dead, but I'm quite sure that problem is not strips related.
          I don't know what voltage level is at output of inverter board (samsung SSL400_3E2A) and how...
          10-09-2022, 11:10 AM
