Lg 47le5400 possible main board issue
  • cherokee.warrior
    • May 2017
    • 87
    I have a LG 47LE5400-UC.AUSWLHR. With an issue that I think maybe a main board problem but I wanted to see if anyone else has seen this with this model of TV. See if anyone may already know what is causing the issue and the possible fix. Doesn't hurt to ask before cracking it open for a look see. Here is a link to a video of it in operation.
    https://youtu.be/3di-Npvc4Zs
  • cherokee.warrior
    • May 2017
    • 87
    Re: Lg 47le5400 possible main board issue
    I'm getting this on all hdmi inputs and when watching the TV signal over the air. I've not checked the other inputs but suspect it's the same on them as well.
    • RJARRRPCGP
      • Jul 2004
      • 6301
      Looks like the T-con or the mainboard in general...
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      "Β‘Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MΓ­ mismo
      • cherokee.warrior
        • May 2017
        • 87
        It looks to be a main board /tcon board all in one board.
        Uploaded service manual to this post.
        • freakaftr8
          • Oct 2012
          • 3743
          Try heating up the main board with a hair dryer and see if the problem persists
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
          • cheeky2
            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
            by cheeky2
            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
            01-08-2024, 05:56 AM
